POLL......Tyre pressures
phoenixv6quattro Mar 29, 2010
  1. phoenixv6quattro
    phoenixv6quattro staylowmovefast
    1,396
    Hey guys, just a quick one......
    What pressures does everyone run their tyres at? Been experimenting and I am eager to know what everyone else runs at on OE alloys or aftermarket alloys....Obviously with the latter, tyre sizes vary with alloy size/width. So what pressures did you/do you choose to run?
    Thanks Fellas
    Ollie
  2. Foxmeister
    Foxmeister Fired Up!
    1,785
    usually always 32psi rear and 30 front.
  3. jcb
    jcb Active Member
    4,132
    13
    depends on tyres.
    I have 235/40 on 8.5J rims
    30 front 34 rear. any more up front and I find it gets a bit understeery
  4. Mike B
    Mike B Well-Known Member
    1,102
    40
    Wnen I bought my 2.5 TDI last july I found all 4 were between 18 and 20 psi so I assumed there were problems because the sticker said 38 allround ! Pumped them up and they are all still thereabouts so can only assume that the previous owner did not bother but it must have dragged his mpg down.They are standard quattro 205 55 16s abit worn on the edges but this may be the low pressures he had had it for three years and never checked them because they seem to be older than that and will need renewing soon.
  5. Oranoco
    Oranoco Well-Known Member
    3,991
    407
    32 all round typically, seems to work ok
  6. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    32 all round on 225/45/17
  7. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group s tronic
    3,936
    732
    32 on Audi 16" rims.
  8. phoenixv6quattro
    1,396
    Interesting.........Thanks guys! I am running 36psi on 225/45/17's on 8J's. The car is a -45mm lowered V6 avant. I have gone off the reccomended S4 pressures which is 36 psi all round on exactly the same size rubber as I am using....What do you think/any feedback guys?
  9. Foxmeister
    1,785
    Do you not feel a bit unstable when cornering in the wet???
    Tend to find especially the rear from about 34 up will feel like that unless your running a fully laden car, only time to increase your pressures. Give 32 a try n see how it feels, should make a slight difference.
  10. phoenixv6quattro
    1,396
    Thanks Foxy! I will switch in the morning! Funny you should mention unstable wet cornering. I was actually thinking that tonight on the way to work!....All I am trying to do here is learn/grasp different tyre pressures and the effects they have on the overall performance/handling of the car (or any car for that matter).
  11. THE MONSTER
    THE MONSTER Member
    252
    Tyre pressures 32 psi all round for me have Dunlop Sport 9000 on 235/45/ZR 17...
    I do swop the front to back from time to time to even out any wear with directional tryes that is the only way to do it..
  12. audinary
    audinary Complete And Utter Member
    676
    32 at front, 34 rear, same pressures the Merc my wheels came from was supposed to run.
    My wheels are 7.5j at the front, 8.5j at the rear (the Merc was RWD) and the setup feels pretty much spot on to me.
  13. AB5QTS
    AB5QTS Member
    228
    9
    My quattro says 36 front and 34 back.
  14. aragorn
    18,538
    865
    remember pressure will change depending on the cars weight and the tyre size.
    a 225/45r17 should have more pressure in it than a 205/55r16 on the same vehicle
    similarly a quattro is a heavier car so will have more pressure, and an S4 is heavier again.
    Fuel flap on ours says 32 all round for normal driving so i go with that. If i'm doing lots of motorway or load carrying i'll increase it, came down from scotland at the weekend with a boot full of landrover bits, so i put the front up to 34 and the rear to 36.
    Also i never rotate tyres to "even out" wear. I always fit the new tyres to the rear, and move the part worn rears to the front. I feel the rear of the car is less controllable, and provides less feel, so knowing the rear is on stickier rubber than the front gives you more confidence in the car. Having ditchfinders, or even more worn tyres on the rear, means you can have the back end step out without any warning from the steering as the front end still has plenty of grip.
  15. AudiMaz
    AudiMaz Member
    178
    I'm pretty sure i'm running 35psi all round on mine. Tyre size are 235/35/19.
  16. CraigG
    CraigG Member
    190
    im on 36psi all round as per fuel flap. upto 40 when on long runs/fully loaded
  17. Broken Byzan
    13,237
    465
    TQS 36 front and 38 rear normally, if i was carrying more weight i would wadge it up a bit
  18. audinary
    676
    Amen to that. My "Triangle" brand rear tyres were, i'm certain, central to the crazy lift-off oversteer problems I was suffering from with my previous wheels (soon to become my "winter" / MOT wheels
  19. ian52
    ian52 2000 a4 1.8tqs-yellow
    1,199
    Is there a reason so many of you run more pressure at the rear? I have always had more in the front,34 front 32 rear on 225/45/17.
  20. Broken Byzan
    13,237
    465
    I prefer the way the car drives with the pressure set like this is my reasoning tbh
  21. Broken Byzan
    13,237
    465
  22. Fraser
    Fraser Member
    584
    this is what i use - seemed to be the recommended pressures over on rs246
  23. phoenixv6quattro
    1,396
    Because of the wide range of pressures stated here (32-40psi) Im guessing that a lot mof you think "bol**x" to the reccomended pressure specs and are just sticking with the best of what you have tried and tested. And rightly so! Aragorn, did you ever get that equation from that dude for calculating tyre pressures?........
    Droppd mine down to 32 psi this morning. The car does feel more stable when hard coenering in the wet, but feels less responsive (not as sharp) when flicking the car about.......
  24. Geeman
    Geeman Low Life
    1,318
    I run 32 all round on mine... 215/40/18's
    But even if I had 225's I'd still run 32.
    The TT runs higher than that though... Rach has them up at the recommended Audi pressures.
    I might bump mine up to 34 all round this afternoon and see if that makes any difference to the driving...
  25. phoenixv6quattro
    1,396
    Thanks for all the detailed responses/feedback guys. I am keeping mine at 34 psi which is a happy medium...
    Ollie
  26. Izzy1
    Izzy1 Vorsprung Durch Technik
    395
    10
    normally have mine between 38 psi on all four on standard 15's
  27. Matt82
    Matt82 Active Member
    2,365
    i just use the OE pressures, hardly like its a drivers car or anything
