Polished Bliss: Neglected BMW M3
WX51TXR Nov 21, 2007
  1. WX51TXR
    WX51TXR Polished Bliss
    1,452
    14
    First car of the week, all done by Clark...
    This was the latest detail, a full correction job on what was even admitted by the owner as a pretty neglected M3, here it is in the Unit yesterday morning looking pretty flat and dull, the paintwork was covered in swirls and RIDS:
    The wheels were rather manky too....
    Oh joy! :rolleyes:
    As i mentioned, the owner had amitted that he had got a bit lazy with the car and hadn't given it the attention it needed and deserved (the car has only done approx 30k but you wouldnt have guessed it to look at it), so this detail was hopefully to be what would give him a "kick up the ar$e" and make him look after it properly from now on :)
    So, on with the detail:
    9:30am:
    A slight delayed start as i had to take the owner home after he dropped the car off, so once back i took the car outside ready to be washed:
    This would be a good time to play with the new toy too, a nice new Karcher complete with hot water, ooooooooooh! :hubbahubba:
    We've found that unless really dirty, most cars dont always need foamed as part of the pre-wash when rinsed at high pressure @ 35/40 degrees, and this was the case for the M3. So it was given a good rinse and i then set about cleaning the arches with Meguiars Super Degreaser cut 4:1 and door shuts etc cut 10:1.
    Next up was the wheels, which were going to need a fair amount of work - just over 2 hours of work actually! this is what they looked like after a strong solution of Meguiars Wheel Brightener (menz 7.5 didnt do much, unsurprisingly):
    I eventually got them as clean as possible with the use of Autosmarts Tardis and a clay bar, but obviously this took a while due to the design of the wheel!
    At this point the heavens opened so i stopped taking pics and got on with the rest of the wash process, the car was washed with the 2BM before using nearly a litre of Tardis, as you can see below - the car was covered in tar spots:
    The engine was soaked with Super Degreaser and rinsed @40 degrees after a few mins of dwelling time.
    Last job was to clay the car, and i used Zymöl Lehm Clay for this as the paint was pretty rough. This was followed up with one last rinse @ 40 degrees and i then put the car inside to dry off as it was still pi$$ing down outside!
    Total Wash time: 4.5 hours
    14:00pm:
    Once the car was dried off i taped up and took paint readings, which showed everything was nice and original at an average of 120 microns, although the lower parts and rear bumper were around the 85/90 mark.
    I was going to need a fair bit of paint as the defects were bad, however due to the car being red (why do defects not show up that well on red?) they dont show that great on camera - yes they look bad enough but they were worse in the metal!
    I did a test section with Menz IP 3.02 and a Meguiars Polishing Pad @1800rpm's. This did sweet f*ck all to be honest as what appeared to be swirls at first were in fact all random scratches (i'm sure there were some swirls under there too!), i'd have needed 2 or 3 hits per section to even achieve anything like an acceptable level of correction, this paint was pretty hard too as you would expect.
    Luckily, we have just taken delivery of a bunch of new 3M stuff so i decided to try out the 3M Compounding Pad:
    First impressions were "damn this thing is hard!", it makes the Megs Cutting Pad feel like a finishing pad!
    However, this is a good thing as this is what my new test section looked like after i'd worked the IP with the 3M pad@1800rpm's:
    Result :thumb:
    Combined with the 3M backing plate, i found the Compounding Pad a doddle to use, finding that it followed the contours of the panels with relative ease despite the firmness of its structure. A very high level of correction was achieved first time with several initial slow passes with firm pressure at the beginning of each set. The pad allowed for an LSP finish (although not as sharp as it could have been) but i wasnt paying too much attention in finishing down as i was going to go over the car again anyways :)
    Here's a 50/50 on the door, you can see how much duller the un-polished side is:
    And completed:
    The side strips were also polished, with a Megs Polishing Pad & 3.02@1200rpm's, however i made very fast passes with minimul pressure to keep heat down:
    Some people tend to leave these after they've removed the tape but i hate seeing them all swirly compared to the rest of the de-swirled paint :)
    21:00pm -End of day 1:
  2. WX51TXR
    1,452
    14
    09:00 - Day 2:
    I finished off the de-swirling - the front and rear bumpers/side skirts etc were polished with the Megs Pad and Rotary also, before i did the smaller areas with the PC and a 4" spot pad.
    11:00am:
    Next stage was to refine the finish even further (and remove the odd buffer trail) with a 3M Finishing Pad and Menzerna P085RD@1800rpm's:
    Fully worked and ready to buff off:
    This made a huuuuge difference to the clarity of the solid red paint:
    14:00pm:
    The 2nd stage machine polishing only took approx 2 hours but by the time Angela had made me have my lunch :)p ) it was nearly 2 o clock so time was nipping on a bit.
    As always, after the polishing was done i removed all the dust with a Zymöl duster and wiped down all the shuts etc before getting the Vintage out the fridge. This was applied to a German Applicator Pad as always:
    And applied to the whole car and left to cure:
    As always, while the wax cured i detailed the interior, polished the exhaust tips (these were proper black and needed compound), dressed the arches with Megs All Season Dressing, sealed the wheels with Poorboys wheel Sealant and did the tyres with Blackfire Long Lasting Tyre Gel.
    I also applied 303 Aerospace Protectant to the Engine and buffed off:
    The wax was now ready to come off and i'd managed to get such a thin layer onto the paint that it didnt even need a wipe down before the pics :)
    The car was now back to how red should look :icon_thumright:
    So around 20 hours work in total for this one but i was quite pleased with the outcome, just wish the difference in the before and afters was as clear in the pics as it was in the metal :rolleyes:
    Thanks for looking!
  3. john2garden
    john2garden Gonad
    399
    Brilliant job as ever, just wish you were closer to me.
    One thing I was going to ask - do you ever take the wheels off to clean them, would that not be easier?
    Or is it too much hassle???
  4. Boydie
    Boydie Guest
    Looking great!
  5. tris88
    tris88 Member
    65
    Nice job, I think it's time you lot moved to the South East... :icon_thumright:
  6. ChuckH
    ChuckH Member
    159
    Awesome, Simply Awesome work !!!!!!!!!!!!!!
  7. WX51TXR
    1,452
    14
    Most of the time it's easy enough to work from the front using brushes and mitts, but as above, sometimes it's debatable whether taking them off would be easier and quicker. One of the minor issues to consider is that if you start taking things off and sitting cars on jacks while you work, there's a greater chance of something going wrong. I may be a worry guts, but if we can get away without resorting to mild mechanics then I feel more comfortable. :)
  8. jr001
    jr001 Member
    380
    A truly minging car to begin with, like so many M3s on the road. A total transformation. Top job.
    The wheels, if they've to come off then the owner does it!
    Well done to Clark.:icon_thumright:
  9. jesters3
    jesters3 Active Member VCDS Map User
    1,516
    My god, I really am just in awe of your exceptional workmanship. Especially the engine bay, jesus you could eat your dinner off it and then have a shave in the mirror-like bodywork.
    :anbet: :anbet: :anbet: :anbet: :anbet: :anbet: :anbet: :anbet:
    Does the degreaser really do that and is it really that simple (ie cover up, spray on, leave, spray off, engine on, dry up, buff up)??
  10. Ian W
    Ian W Active Member
    1,058
    12
    Just found this detailing area of this site and the work you do is :hubbahubba:
    I'd love to get my S3 done but im guessing your not based in the North West :sadlike:
  11. Covenant
    Covenant Member
    246
    Aberdeen :)
    Just think of it as an excuse to drive for the fun of it. I took a day off work and drove through the mountains to get there - awesome experience.
  12. Defratos
    Defratos You’re Dethpicable!!
    2,232
    amazing result, another nice job :beerchug:
  13. alnes
    alnes Member
    45
    very nice job, i have been in the body shop trade for 24years and must say you are good, it takes a certain type of tradesman to do this job, well done............:thumbsup:
  14. WX51TXR
    1,452
    14
    Yep! When it comes to engine bay work, product choice counts for a lot, the actual doing is is straightforward enough (unless you are working on an Alfa!). :laugh:
