I love modifying my bike has a list of mods as long as my arm!! I started modding the A3 but with all the issues ive had with it im not sure its worth putting the money into it.
Once I've got it running sweet I may consider where to go from there. At the mo I've got the HP PAS pipe to replace which should be on monday, got to change the rear springs and shocks then do the rear discs and pads. The main bit that's holding me back from modding the car is the turbo has some play in the shaft and the LTFT is hovering between 17-20% so I believe the turbo is on its way out. everything else on the vac and intake side has been replaced that's the only bit left And I'm having trouble justifying to myself if its worth spending £500 on a turbo for a car thats done 105k.
All my other cars haven't stayed standard. If it isn't broken it has got enough gadgets is my moto
Here's the list of what I have done to the car:
New head unit
PCV rebuild with silicon hoses
All Vac lines replaced with silicon
turbo pipes replaced with silicon
S2000 air filter mod
dump valve
N75
hockey puck valve
inlet manifold gasket
VR6 clutch and G60 flywheel
A/c condenser
front shocks and springs
front brakes
injector seats
aerial seal
window runner clips
passenger wing mirror
boot latch
cruise control
comfort indicators
all engine mounts
cambelt and water pump
alternator
2 new headlights plus HID conversion
ignition coil wiring loom
countless ignition coils!!!!
No doubt there's a few bits I missed. Thankfully I do all the work myself would of cost me a fortune otherwise.
I've got all the bits for sai delete so may do that just because.
What bike you riding these days?
