Pls help with 2 fault codes!
.Jas. Feb 15, 2013
  1. .Jas.
    .Jas. Member
    131
    I have had a scan done and the following 2 codes showed up.
    They appear to be fan related, although I've never seen the car go past halfway on the temp gauge. Any opinions on how to fix them are welcome...Cheers
    06471 - Control Module 2 for Cooling Fan
    P1947 - 001 - Over-Temp
    Freeze Frame:
    Fault Status: 01100001
    Fault Priority: 0
    Fault Frequency: 39
    Mileage: 179933 km
    Time Indication: 0
    Freeze Frame:
    RPM: 798 /min
    Torque: 97.5 Nm
    Speed: 0.0 km/h
    Duty Cycle: 13.8 %
    Duty Cycle: 13.8 %
    Duty Cycle: 13.8 %
    Duty Cycle: 13.8 %
    001683 - Fan 2 Control Circuit
    P0693 - 001 - Short to GND - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 0
    Fault Frequency: 68
    Mileage: 179933 km
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Duty Cycle: 9.9 %
    Voltage: 12.01 V
  2. NHN
    29,295
    1,701
    Show the full log please.
  3. .Jas.
    .Jas. Member
    131
    Is there more then? I'll get back to him and ask for it all if there's more
  4. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Team Akoya TDi saloon Audi S8
    15,161
    1,121
    What's wrong with the two fault codes?
    They show the fault codes, the log won't show any more apart from part numbers and version number.
    Looks like a cabling fault.
    Have you checked the plug and cables?
    Do the fans work?
  5. .Jas.
    .Jas. Member
    131
    Thanks Scott. I'll look tomorrow (at the plug & cables), but are there 2 fans? I know for sure 1 of them is working as I can hear it now and again.
    BTW, I have a 3.0L V6 TDI
  6. NHN
    29,295
    1,701
    Well where do I start, well he hasnt given us any info about the car, what year, what chassis, what engine, what gearbox, etc etc, do I really need to go on???
    Some cars have known problems related to these codes, some dont, so to advise more precisely we need more info, thought that would be obvious tbh.
    Always provide a full log of the car if you're asking for help aswell as the car info.
  7. ScottD3
    15,161
    1,121
    Car details is a must, true and he finally posted them.
    Any other faults with in the logs could be usefully but that single line on its own about posting more winds me up.
    It reads like your wanting segregate people if it's not a gen version, that might not be the case and just me reading more in to it. :thumbsup:
  8. .Jas.
    .Jas. Member
    131
    I can easily expand:
    3.0L V6 TDI Jan 2007 B7 Chassis Auto gearbox No DPF 111k miles
  9. NHN
    29,295
    1,701
    Keep it on topic Scott.
  10. ScottD3
    15,161
    1,121
    On it.
    Quick google brought up nothing.
    A polish site suggest checking the cables, fuses and plugs.
    I'm out of ideas. :)
  11. .Jas.
    .Jas. Member
    131
    Cheers Scott, thanks for your help. I'll report back later... :)
  12. PAULF
    PAULF Active Member VCDS Map User
    712
    66
    A couple of wiring invest thoughts, applicable to most sensor/loom combination faults......
    A short to ground suggests a short to ground - a connector full of fluid or chaffed loom would cause this
    An overtemp (or 'High' or 'Low' fault) in combination with the above suggests a connector needs cleaning, or a loom has chaffed (causing a short/open circuit) on the temp (or whatever) sensing line.
    Both of the above could also be caused by breakdown of the module, assuming it's common to both, although I would have expected a module fault code.
    They may also be caused by a breakdown of the temp sensor (short/open circuit causing high reading and short to ground fault)
  13. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,803
    192
    The op originally posted a full log but NHN edited it and asked for a full log purely to wind up scott!!! hahahahaha
    The evidence:
    The original post was edited:
    Then NHN reply to this post also 2 weeks ago:
    And then scottb5 gets upset!
    I daresay i will be edited out now too lol... but hey it breaks up the day :p
  14. NHN
    29,295
    1,701
    I'm afraid you're wrong on all counts, nothing was removed from his log at all, he didnt post a full log, he posted up the 2 logs in a table, which I copied & added to his 1st post & the OP was made aware via PM which he acknowledged.
    So rather a pointless friction causing post IMHO.
  15. Sandra
    Sandra Moderator Staff Member Administrator Moderator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter
    25,758
    8,833
    Tut tut Tom, please find some other way to break up your day please.
