PLEASE READ ANY HELP ME. CAR IS BROKEN AND WON'T TURN OVER...
CorrDogg58 Jul 2, 2013
  1. CorrDogg58
    CorrDogg58 Member
    92
    Car decided to spit out a lot of dark smoke on the way home Sunday evening. Stopped and called the AA, got towed home. Looked at the car yesterday, seems to have dispatched all of the oil somewhere as it has no oil in it now. The car won't turn over and when it does (with a battery booster pack) it revs itself up to 3000rpm and back down again and repeats. When I rev the car myself it kicks out a lot of white smoke and I mean a bloody lot :(
    Any ideas on what the problem could be!?
    Help would be much appreciated.
  2. Turbo jay
    Turbo jay Leather repair specialist
    577
    69
    Sounds like the turbo, I wouldn't be starting it mate get it towed to a garage ASAP. I had same happen to me on my old a3 dumped all the oil into exhaust and intercooler.
  3. percha
    percha New Member
    13
    Turbo has gone maybe?
  4. CorrDogg58
    CorrDogg58 Member
    92
    im getting a compression tester put on it tomorrow. Is that going to bring up anything? I'm worried its going to be something worse like a cracked piston or ring failure :( because there was a horrible noise coming from inside the engine when I shut the car off, kinda sounded like a bit of metal bouncing/spinning around loosely
  5. NHN
    29,298
    1,701
    Tell me you didn't turn it over with all the oil dropped out, isn't that like 4 turbo's now?
    Is your car stock as that's a fair few turbo's to go in 2 years.
    Sorry for your issues, but we have a brand new turbo boxed if interested.
  6. CorrDogg58
    CorrDogg58 Member
    92
    i may have turned it over without oil in it as the AA bloke didn't think that was a problem. It wasn't until I woke up the next day I checked the oil level :( do you think the turbo could cause all of this? Or it's something else? I'm going to put some oil in it tomorrow before the compression test
  7. Turbo jay
    577
    69
    Best just go get a diagnostic scan on it mate but it does sound like the turbo has gone and if you've been trying to start it with no oil in then you may have caused further damage but fingers crossed you haven't.
  8. CorrDogg58
    CorrDogg58 Member
    92
    i have the turbo on warranty at my local Audi garage. So if I get it on the back of a recovery truck and taken there, do you think that's a good idea? And if I've done more damage surely that's caused because of the turbo so they should repair all damages because the turbo is at fault...
  9. Turbo jay
    577
    69
    yea I'd take it back there if its under warranty, but I certainly wouldn't be saying that you tried to turn it over because if you have done more damage to the engine then that would of been as a result of you trying to turn the engine over without oil in it. Anyway hope that it is just the turbo then at least it's covered under warranty.
  10. NHN
    29,298
    1,701
    Just don't tell them you turned it over & if its from an audi dealer, then definitely go back to them, don't bother putting oil in just get it to the dealer & don't start it again.
  11. CorrDogg58
    CorrDogg58 Member
    92
    okay. Thank you for your replies, much needed and I won't be telling them I tried to turn it over haha. Just hope it is the turbo as that's the only part covered on warranty, as the original warranty has run out
  12. CorrDogg58
    CorrDogg58 Member
    92
    the only thing I'm worried about is if it isn't the turbo, then it's stuck 30 miles away from my home and obviously not drivable :(
  13. CorrDogg58
    CorrDogg58 Member
    92
    I've checked the egr valve and when I rev the car, the smoke comes out of the breather pipe. Maybe ring failure or a cracked piston??? Anyone had this before?
  14. hades-
    9,481
    646
    after been told not to start it you have ?
    thats just silly
    NHN likes this.
  15. CorrDogg58
    CorrDogg58 Member
    92
    no this was when the AA bloke looked at a few things Sunday night
  16. hades-
    9,481
    646
    AA most know **** all
    1 tried to start my car when the oil preasure light was on saying it wouldnt hurt to drive 200+ miles home
    if audi supplied and fitted the turbo id be on the phone to them to get it recoverd.
    they will tell you about charges for looking if it isnt the turbo tho.
  17. CorrDogg58
    CorrDogg58 Member
    92
    i'm gonna put a litre of oil in it today and do a compression test as quick as possible to see if it is something else... I don't want it to get all the way to Audi and find out its not the turbo
  18. chris.vincent3
    chris.vincent3 Own a BMW now, HOWEVER I still own VCDS! VCDS Map User
    604
    34
    People are trying to help you. If I was you I would listen to their advice, stop trying to convince yourself you know it's something else after the help you have been given.
    Chances of it being a piston or piston ring is pretty small.
    I too am +1 for turbo.
  19. CorrDogg58
    CorrDogg58 Member
    92
    the person who is advising me to do the compression test is a mechanic and a good one at that... He had the same problem with his car before, so I'm not going against anyone's advise on here. I'm just trying to cut down the options before its too late :(
  20. Chillout
    Chillout Active Member
    609
    50
    I notice you said it is producing a lot of white smoke that's a good indication of coolant/water head failure or oil cooler but as for your oil disappearing that's slightly odd
  21. CorrDogg58
    CorrDogg58 Member
    92
    And the noise it was making didn't sound good at all :( my mechanic has said he thinks it's ring failure or a cracked piston. As when this happens the car dispatches all the oil every time you put some in
  22. Chillout
    609
    50
    Is your coolant ok or any mayo on the cap or is the intercooler full of oil
  23. chris.vincent3
    604
    34
    Some people on this forum are mechanics, such as myself. What makes the mechanic you know a good mechanic?
    The smoke coming out your exhaust could be where the turbo has sucked the oil out the engine and is burning off in the exhaust.
    Same thing happened to my dads 170 A3. The turbo's on these cars are common to failing so there are a lot of fellow owners with this experience a quick search will bring up many other threads with the same symptoms leading to turbo failure
    EDIT:
    TDI Turbo failure - YouTube
    TDI blown turbo - YouTube
