Please post A3 on 19" with 225/35/19 tyres.
drnutta Jul 25, 2010
  1. drnutta
    drnutta Member
    372
    Hi guys,
    Getting all confused now with the wheel and alloy sizes.... which has caused me to delay my VMR order.
    I have now heard that if i go for 225 tyres the speedo will be wrong... ho hum...
    Can someone with 19" and the 225-35-19 wheels please post some pictures and perhaps explain what the heck is going on :)
    thanks
  2. warrenlord
    warrenlord Member
    771
    15
    this could also help me out too.
  3. N8
    17,163
    720
    19 x what?
  4. drnutta
    drnutta Member
    372
    VMR 708 19"
    8.5X19" ET48
    For me
  5. warrenlord
    warrenlord Member
    771
    15
    Yeah same fitment am trying to work out.
  6. drnutta
    drnutta Member
    372
    guys any help?
  7. Lee_R
    Lee_R Active Member
    2,499
    12
    Loads of people run 225's on 19's without issue. Dont worry about the speedo issue, the effect will be very minor
  8. drnutta
    drnutta Member
    372
    How minor are you talking about? I also am fearing the rubbing.... I'm not that young anymore :)
  9. Lee_R
    Lee_R Active Member
    2,499
    12
    around 1-1.5%
    They wont rub unless you go down far on coilovers and coilovers are for the young with healthy backs!
  10. drnutta
    drnutta Member
    372
    Yip I already have the coils... which were actually bought for the VMRs just wanted to know which size now 18 or 19... inches...
  11. Anders3404
    Anders3404 New Member
    10
    Code the correct tire circumference in VCDS
  12. HIGGINS
    HIGGINS Member
    528
    15
    im lowered around 30-40mm on coilovers and its rubbing :( 225-35-19 rs4 wheels
  13. tcardio
    tcardio Well-Known Member
    1,037
    308
  14. drnutta
    drnutta Member
    372
    tcardio what tyres are these and are they rubbing?
    Views on going 18?
  15. tcardio
    1,037
    308
    unless your roads are atrocious, then I would go 19's. I run on Yokohama S-drives, H&R coilies with VA 2 spring and they rubbed intermittently for 200 miles and then nada. I prefer the 19's. ET 48 is about right. I would prefer ET 50 for this wheel but 48 is just fine. You can disassemble the centercap and paint the base your car color. The outer ring and the 4 rings are clip on. ECS tuning has colored bolt covers. If you prefer black then order the TTS centercaps at audi.Not to bust this thread but take a look at DPE MT 10 wheels. I'm kinda tired of the RS4 reps as they are pretty much played out.
  16. drnutta
    drnutta Member
    372
    Thanks mate... what us the tire size?
    Have you got a close up of the wheels also?
  17. Lee_R
    Lee_R Active Member
    2,499
    12
  18. RAPS3
    RAPS3 Well-Known Member
    1,142
    135
    That'll probably be as the feltlike inner arch liner has a nice groove in it where it is coming into contact withthe leading edge of the tyre :)
  19. drnutta
    drnutta Member
    372
    Paul how are you find your ride ?
    I'm still worried about going 19"
    With the limited replies kinda worried with this purchase...
  20. N8
    17,163
    720
    Go out in someones car with 19s dude
  21. drnutta
    drnutta Member
    372
    Would love to mate but no one is near cambridge :)
  22. N8
    17,163
    720
    Where you live - fail - haha
  23. tcardio
    1,037
    308
    Take some advice from nate. His car is pure sex and totally baller. Rubbing is nothing to worry about and the 19's are worth it. The tire rubs on felt anyways. Look at some posts where peeps run 20's. anyways 225/35/19
  24. N8
    17,163
    720
    Wow! Love you too tcardio :wub::wub::wub:
  25. S3RYE
    S3RYE Interior Next!!
    3,448
    71
    get a room you two!
  26. N8
    17,163
    720
    Its ok Ry, I love you too :yum:
  27. RAPS3
    1,142
    135
    I find the ride ok.
    Its more harsh, but you cant expect much else, I've lowered mine of H&R Springs and then put the 19"s on.
    There is a notable difference in ride, but I like it, if I had the spare cash I'd probably go for coilovers, not as I want it any lower, but would prefer to know that the springs and dampers were matched, rather than be on OEM dampers and lowered springs.
    Its not bad though.
  28. N8
    17,163
    720
    Its so weird how I prefer the ride on 19"s, really is.
  29. S3RYE
    3,448
    71
    ahhhhh :blush:
  30. RicoS3
    RicoS3 Sprint Blue is the new Ibis!
    622
    70
    Here's my S3 on 19's, ET44 and H&R springs. Because of the rim, I went with 215's to prevent rubbing at the rear as Matt Andrew had the same rim and 225 tyres and they rubbed, only slightly though. It settled and lowered more after this pic by the way.
    I then removed the springs because they themselves were making a very strange clanking noise. At this point I went back to 225 tyres, to make the arch gap look better on stock springs. It's being lowered more on Eibach Pro's at the front only as the offset and rim size at the rear is just right for me. Here's how it sits right now, but before being lowered at the front.
    If you've got coilovers, then you'll be able to set it up to look good and have no rubbing surely? If you're looking for a deal on tyres, check out my sig. I've 4 brand new, unused FK452's sitting in my garage doing nowt. I swapped them for the 215's. I've an exact same set on the S3 right now, 225's and they are top. Ican hoon it around if need be. I don't do track days, so no need for anything to help out there. Hope this helps. :icon_thumright:
  31. N8
    17,163
    720
    Rico your such a lovely lad, and your car is beautiful. Try and come to edition38 this year.
  32. scottie123
    scottie123 (●̮̮̃•̃) (●&#
    1,972
    Edition 38. Very handy, I appear to be off work that week :)
  33. sub39h
    sub39h Active Member
    2,502
    Agreed. that has to be the nicest car i've seen on here
  34. S3RYE
    3,448
    71
    I think if I ordered another s3 it would be same spec as yours Rico. It's special.
  35. N8
    17,163
    720
    That would be ace if you could come Scott.
  36. scottie123
    1,972
    I will try my hardest to show :)
  37. RicoS3
    622
    70
    Aww shucks guys! Cheers for the comments. I'd love to make ed38, but for a number of reasons it'll not be possible. I've only started this "modding" recently, so don't think I've done enough to merit attending a show. I'm also a slack bandit and so the car is generally filthy, so because of a mixture of naivety and generally laziness, I'm not making any plans. Plus, with a 5 week old, a wife that isn't medically fit to drive right now and the fact that I'm in the far North of Scotland, it'll take a bit of planning, lol, but it's not really possible for me to get away for a wee jolly right now! Maybe next year guys. I have some serious plans for a new car and mods, so next year will be interesting. :ninja:
    I'll be watching with great interest though, so I expect to see some tidy pics.
    drnutta - sorry for the thread hijack. 225's are the way forward for you and check out my sig man!!!!
