Please, please, please can somebody help !
GavConner Jul 11, 2008
  1. GavConner
    GavConner Member
    70
  2. MarcQuinlivan
    MarcQuinlivan Active Member
    2,539
    turning over but wont start? could it be a problem with the immobiliser? have you tried your other key?
  3. GavConner
    GavConner Member
    70
    No, my other key is at home and I can'tget there without the car
    Do you think it would turn over with the immobiliser not working though ?
    I'm baffled !
  4. a3norwich
    a3norwich Not anymore - Back 2 BMW (shh)
    359
    Could someone else get you the key?
    How old is your car? Roadside assistance?
  5. Khufu
    Khufu Well-Known Member
    5,704
    31
    where did the pop noise sound like it was coming from? Was it the stereo or instrument cluster? What fuses did you check, there are a few in the engine bay on top of the battery as well as the ones at the end of the dashboard. When you try to start it does the immobiliser light stay on?
  6. Gti Jazz Blue
    Gti Jazz Blue Active Member VCDS Map User
    1,655
    The fact that you heard a pop would suggest that a fuse has blown. Have you checked all of the fuses ? There are two fuse boxes one in the engine compartment and the one at the side of the dash.
    If there was am immoboliser issue it would start and then die straight away.
    Paul
  7. GavConner
    GavConner Member
    70
    Thank you so much guys for all your help
    I checked the fuse board at the side of the steering wheel and the car install people had left a wire.
    They had forced a wire straight in to fuse 28 (I think) and because the loose wire had hit metal it fused.
    Replaced it for another 10 amp and now the car is alive again ….. HOOOOOORRRRRRAAAAAAAAY
    Still got a problem with the radio but I can live with that for now
  8. Khufu
    5,704
    31
    glad you got it running, but it sound like some cowboy work had been done to your car!
  9. emzino
    emzino Active Member
    1,231
    Good thinking there Paul
