PLEASE HELP - Quick Ecu coding question for any vcds gurus???? 2009 a3 2.0 tdi 140.
TDIDAN Dec 22, 2011
  1. TDIDAN
    TDIDAN New Member
    To cut a long story short my ecu is water damaged because of a remap where the ecu has been opened up, ive now found another used same pt no and had my original backup software (from before i had the remap) reinstalled in the new ecu. (So its basically a clone) - So i was kinda thinking because i had the new ecu cloned it would plug in and work straight away. However ive plugged it in and tried it and it still wont start. Vcds is sayng its not even communicating so im now thinking it will perhaps it will still need coding in and immobiliser matching irrespective of the full clone.
    I have vcsd is it possible to do it myself or do i have to go the dealers for them to use VAS ?
    Any help is much appreciated as im using the bus over xmas :(
    Heres my vcds report from when the original (remapped water damaged faulty ecu was fitted):-
    http://www.audi-sport.net/vb/new-a3...d-my-way-home-tonight-now-wont-start-all.html
    Heres the current vcds report from now the ecu is fittted:-
    Thursday,22,December,2011,18:21:46:46862
    ChassisType: 1K0
    Scan: 0103 08 09 10 15 16 17 19 25 42 44 46 47 52 56 77
    VIN:WAUZZZ8PX9zzzzzzzz Mileage:39790km/24724miles
    01-Engine-- Status: Cannot be reached 1100
    03-ABSBrakes -- Status: Malfunction 0010
    04-SteeringAngle -- Status: OK 0000
    08-AutoHVAC -- Status: OK 0000
    09-Cent.Elect. -- Status: Malfunction 0010
    10-Park/SteerAssist -- Status: OK 0000
    15-Airbags-- Status: OK 0000
    16-Steeringwheel -- Status: OK 0000
    17-Instruments-- Status: OK 0000
    19-CANGateway -- Status: Malfunction 0010
    25-Immobilizer-- Status: OK 0000
    42-DoorElect, Driver -- Status: OK 0000
    44-SteeringAssist -- Status: Malfunction 0010
    46-CentralConv. -- Status: Malfunction 0010
    47-SoundSystem -- Status: OK 0000
    52-DoorElect, Pass. -- Status: OK 0000
    56-Radio-- Status: OK 0000
    77-Telephone-- Status: OK 0000
    Address01: Engine Labels:03L-906-022-CBA.clb
    Part No SW: 03L 906 022 BQ HW: 03L 906 022 BQ
    Shop #: WSC 00000 000 00000
    VCID: 75EAE38A239B20B4
    No FaultsFound
    or DTCs not supported by controller
    or a communication error occurred
    Address03: ABS Brakes (-----) Labels:1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
    Component: ESP MK60EC1 H35 0104
    Revision: 00H35001
    Coding: 13424012092400FBC80F02E8901E00823800
    Shop #: WSC 06314 000 00000
    VCID: 74ECDE8E28E139BC
    2 FaultsFound
    01314 -Engine Control Module
    013 - Check DTC Memory -Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 145
    Mileage: 39792 km
    Time Indication: 0
    Date: 2011.12.20
    Time: 00:02:21
    Freeze Frame:
    Count: 2
    Count: 2
    Count: 4096
    Count: 8196
    Count: 42752
    Count: 0
    Count: 0
    Count: 0
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 145
    Mileage: 39792 km
    Time Indication: 0
    Date: 2011.12.20
    Time: 00:02:29
    Freeze Frame:
    Count: 2
    Count: 2
    Count: 4352
    Count: 8194
    Count: 42752
    Count: 0
    Count: 0
    Count: 0
    Address08: Auto HVAC Labels:8P0-820-043.lbl
    Part No SW: 8P0 820 043 BH HW: 8P0 820 043 BH
    Component: KlimavollautomatH09 0100
    Revision: 000885 Serial number: 8P0820043BH
    VCID: 73EEDD922DEF3E84
    1 FaultFound
    01206 -Signal for Duration of Ignition Off Time
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 145
    Mileage: 39792 km
    Time Indication: 0
    Date: 2011.12.22
    Time: 05:37:04
    Freeze Frame:
    Address09: Cent. Elect. Labels:8P0-907-279-30-H.lbl
    Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
    Component: Bordnetz-SG H54 2801
    Revision: 00H54000 Serial number: 00000008699708
    Coding:15A82F07A0141380EF00001C4F00000000084E0564010003002000000000
    Shop #: WSC 06314 000 08192
    VCID: 48945A7E04E9ED5C
    Part No: 8P2 955 119 F
    Component: Wischer AU350 H10 0040
    Coding: 00056595
    Shop #: WSC 06314
    3 FaultsFound
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 145
    Mileage: 39792 km
    Time Indication: 0
    Date: 2011.12.20
    Time: 00:02:00
    Freeze Frame:
    ON
    Voltage: 11.80 V
    OFF
    ON
    OFF
    OFF
    OFF
    02745 -Bulb for Daytime Running Light; Left
    012 - Electrical Fault in Circuit -Intermittent
    Freeze Frame:
    Fault Status: 00111100
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 185
    Mileage: 39792 km
    Time Indication: 0
    Date: 2011.12.20
    Time: 00:00:00
    Freeze Frame:
    ON
    Voltage: 11.25 V
    OFF
    ON
    OFF
    OFF
    OFF
    02746 -Bulb for Daytime Running Light; Right
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 185
    Mileage: 39792 km
    Time Indication: 0
    Date: 2011.12.20
    Time: 00:00:00
    Freeze Frame:
    ON
    Voltage: 11.25 V
    OFF
    ON
    OFF
    OFF
    OFF
    Address10: Park/Steer Assist (J446) Labels: 8P0-919-475-7X1.clb
    Part No SW: 8P0 919 475 F HW: 8P0 919 475
    Component: PARKHILFE 4K H06 0102
    Revision: 11001001 Serial number: 52330819707905
    Coding: 000003
    VCID: 4182475A27D3DC14
    No faultcode found.
    Address15: Airbags (J234) Labels:8P0-959-655-10.clb
    Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
    Component: Airbag AU1042 H06 0090
    Revision: -------- Serial number: 003000000000
    Coding: 303142413039303030384A55305238503053
    ASAM Dataset: EV_Airba10AURB4 001001
    ROD: EV_Airba10AURB4.rod
    VCID: 49925F7A1FE31454
    No faultcode found.
    Address16: Steering wheel Labels:8P0-953-549-F.lbl
    Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
    Component: J0527 H36 0070
    Coding: 0004012
    Part No: XXXXXXXXXXX
    Component: E0221 H02 0030
    No faultcode found.
    Address17: Instruments Labels:8P0-920-xxx-17-MY8.clb
    Part No SW: 8P0 920 982 C HW: 8P0 920 982 C
    Component: KOMBIINSTR. VDO H15 0830
    Revision: D0H15005 Serial number: 2246H005003556
    Coding: 0004428
    Shop #: WSC 00503 210 83701
    VCID: 39722FBA4F0384D4
    No faultcode found.
    Address19: CAN Gateway Labels:1K0-907-530.lbl
    Part No SW: 1K0 907 530 Q HW: 1K0 907 951
    Component: J533__Gateway H16 0202
    Revision: H16 Serial number:2700K087150884
    Coding: E9A01F061006020101
    VCID: 356A238A631B60B4
    1 FaultFound
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 145
    Mileage: 39792 km
    Time Indication: 0
    Date: 2011.12.20
    Time: 00:02:29
    Address25: Immobilizer Labels:1K0-920-xxx-25.lbl
    Revision: D0H15005 Serial number: AUX7Z0H6FNN05I
    No faultcode found.
    Address42: Door Elect, Driver Labels:8P0-959-801-MIN3.lbl
    Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
    Component: Tuer-SG H03 0060
    Coding: 0000636
    VCID: 438E4D523DCFCE04
    No faultcode found.
    Address44: Steering Assist Labels:1Kx-909-14x.lbl
    Part No: 1K0 909 144 C
    Component: EPS_ZFLS Kl. 233 2301
    Revision: 00H15000
    Shop #: WSC 02069 000 90108
    VCID: 2A5000F6BAA53F4C
    3 FaultsFound
    00778 -Steering Angle Sensor (G85)
    000 - - -MIL ON
    Freeze Frame:
    Fault Status: 11100000
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 39792 km
    Time Indication: 0
    Date: 2011.12.20
    Time: 00:00:15
    Freeze Frame:
    BatteryVolts: 12.1 V
    PD
    Temperature: 6.0°C
    Count: 2
    Steering Angle: 0.00°
    Count: 0
    SteerAng n.Init
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 145
    Mileage: 39792 km
    Time Indication: 0
    Date: 2011.12.22
    Time: 04:59:57
    Freeze Frame:
    Voltage: 11.75 V
    DU
    Temperature: 11.0°C
    RPM: 1498 /min
    Speed: 0.0 km/h
    Speed: 0.0 km/h
    Count: 0
    00750 -Warning Lamp
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 195
    Mileage: 39792 km
    Time Indication: 0
    Date: 2011.12.22
    Time: 05:11:49
    Freeze Frame:
    Voltage: 11.88 V
    DU
    Temperature: 12.0°C
    RPM: 0 /min
    Speed: 0.0 km/h
    Speed: 0.0 km/h
    Count: 0
    Address46: Central Conv. Labels:8P0-959-433.lbl
    Part No: 8P0 959 433 J
    Component: KSG H11 0080
    Coding: 1980200002186D2D8505489AC637
    Component: Sounder No Answer
    Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H04 0020
    1 FaultFound
    01134 -Alarm Horn (H12)
    Address47: Sound System Labels:8Px-035-382.lbl
    Part No SW: 8P3 035 382 D HW: 8P3 035 382 D
    Component: AB2 SUBWOOFERBOXH30 0160
    Revision: 00006 Serial number: 30659850214948
    VCID: 346C1E8E686179BC
    No faultcode found.
    Address52: Door Elect, Pass. Labels:1K0-959-702-MIN3.lbl
    Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
    Coding: 0000636
    VCID: 448C4E4E38C1C93C
    No faultcode found.
    Address56: Radio Labels:8J0-035-1xx-56.clb
    Part No SW: 8P0 035 195 M HW: 8P0 035 195 M
    Component: R Symphony2+ H04 0270
    Revision: 00H04000 Serial number: AUZ1Z4H7176712
    Coding: 0730211
    VCID: 3C7C36AE4031B1FC
    No faultcode found.
    Address77: Telephone Labels:8P0-862-335.lbl
    PartNo SW: 8P0 862 335 N HW: 8P0 862 335 N
    Component: FSE_256x BT H34 0520
    Revision: 00000000 Serial number: 00000005020108
    Coding: 0001222
    No faultcode found.
    End ---------------------------------------------------------------------
