please help p0322 code and no spark
jay106 Sep 8, 2013
  1. jay106
    jay106 Member
    58
    Hi i bout a very clean audi a3 52 plate 84k as non runner plugged my scanner into it and getting p0322 code and got no spark has anyone come across this and where would the sensor be.thanks
  2. jay106
    jay106 Member
    58
    auq engine code
  3. Broken Byzan
    13,237
    465
  4. <tuffty/>
    21,153
    3,834
    16706/P0322/000802 - Ross-Tech Wiki
    16706/P0322/000802 - Engine Speed Sensor (G28): No Signal
    Possible Symptoms
    Engine shuts off
    Engine doesn't start
    Speedometer inoperative
    Glow Plug Indicator Lamp (K29) flashes
    Possible Causes
    Engine Speed Sensor (G28) loose
    Engine Speed Sensor (G28) faulty
    Possible Solutions
    Check Engine Speed Sensor (G28)
    Special Notes
    The Engine Speed Sensor (G28) is also used as a reference sensor for the crankshaft position.
    Other words... crank sensor...
  5. jay106
    jay106 Member
    58
    ok thanks would this stop it sparking it was running then went to start it and it wouldn't fire no spark
  6. <tuffty/>
    21,153
    3,834
    Yes... if the crank sensor isn't working then the ecu won't even now went to spark....
  7. jay106
    jay106 Member
    58
    ok thanks how much are they about? and where is it on the engine thanks for your help
  8. Gops
    3,198
    666
    Over £100. I got mine for £80ish though after abit of haggling at Tps (can tell I'm asain, almost as bad as joe :p). Bit of a bugger to get out but Harlem shake that thing out.
  9. Prawn
    11,506
    3,415
    you sure they're that much Gops?
    I paid £23 at GSF for one when mine went, 15 minute job to swap it over :)
  10. jay106
    jay106 Member
    58
    right a trip to euro car parts and £13 later all up on the button so happy days but stil got water going into oil oil cooler ok so thinking head gasket
  11. Gops
    3,198
    666
    Yeah I went to Tps didn't I! I'm sure it was that that cost me that much.. Got the receipt somewhere..
