Please Help Audi A4 2.5 TDI Quattro Starting Problems/Thermostat
Johnboymason Feb 21, 2013
  1. Johnboymason
    Johnboymason Member
    73
    hi everyone, i have a Audi 2.5 tdi quattro 180, i had the car for 3 weeks with no problems what so ever, then tryed to start it 1 day and just kept turning and turning over and not starting also chucking white smoke out of back which was told was the fuel being dumped, so had it on the snap-on machine and it said it was crank shaft sencor, so changed that and still the same, ive changed 3 glow plugs after testing the 6 plugs and 3 were out and still wont start, i got told it could be the fuel timing been out which was gonna edit with snap-on machine, but the car has to idle between 700-900 revs and the temp be above 80 my revs are fine but my temp is stuck just above 50 as thermostat will be jammed open so bought 1 and been told its a total nightmare changen it, has any1 got any advice on how to change this without taken the timing belt and stuff off or any advive about the starting please help lol
  2. Mike B
    Mike B Well-Known Member
    1,115
    40
    Has the temp been only 50 since you had it?Any heat or not?Try changing the temp sensor the stat is a big job
  3. Johnboymason
    Johnboymason Member
    73
    hi mike i have changed the temp sencor and been like that since i had it
  4. quattrojames
    14,068
    585
    Sounds like you've tried most things, I'll second the CTS suggestion. It's also worth trying a new battery as in my experience a weaker battery really affects the 2.5's starting ability.
    I don;t think you can change the thermostat without doing the timing gear, but Adamss24 will be the man to tell you that. I wouldn;t have thought a knackered thermostat would affect the starting though.
  5. Johnboymason
    Johnboymason Member
    73
    see james soon as i spray a little bit of easy easystart it fires up and runs mint but wont start without that
  6. JimLoskot
    JimLoskot Member
    161
    2nd James' suggestion of a new battery. A weak battery really effects the starting
  7. quattrojames
    14,068
    585
    Where do you spray the easystart?
  8. Mike B
    1,115
    40
    Did you use a genuine CTS?Strange that it suddenly failed to start.If the stat has stuck then you will have to think about belts too but it wont be stopping it firing up.A good battery is vital
  9. Johnboymason
    Johnboymason Member
    73
    just down the air pipe james and it has a heavy duty battery and even with jump leads going through aswell still wont start without easystart
  10. Johnboymason
    Johnboymason Member
    73
    yes genuine mate and battery is spot on
  11. Johnboymason
    Johnboymason Member
    73
    its driving me mad lol
  12. quattrojames
    14,068
    585
    How do you know the battery is spot on?
    For the cost of glowplugs I'd make sure you've replaced them all.
  13. Mike B
    1,115
    40
    How old is the cambelt?
  14. Johnboymason
    Johnboymason Member
    73
    Spot on just had it on vag today codes present are 01375. 01126. 00575 I've changed engine temp and crank sencor
  15. Johnboymason
    Johnboymason Member
    73
    Any body???
  16. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    Have you checked it with VCDS or the snapon kit?
  17. quattrojames
    14,068
    585
    Whats the question?
  18. Johnboymason
    Johnboymason Member
    73
    Just anyhelp I mean I drove about today left it for 20mins and started with a struggle out after that just womt start without easy start
  19. PAULF
    PAULF Active Member VCDS Map User
    712
    66
    Have you checked the pump timing with VCDS?
  20. Johnboymason
    Johnboymason Member
    73
    Not yet aasthermistat jammed out and temp has to be above 80 to edit fuel timing
  21. PAULF
    712
    66
    Block the radiator with cardboard (about 3/4) and run the car, it will eventually get warm enough to check.
  22. Johnboymason
    Johnboymason Member
    73
    Think a will try that lol
