please help!!! A3 TDI wont start!
a3 fkv Feb 6, 2013
  1. a3 fkv
    a3 fkv New Member
    Audi A3 2.0 TDI Sport -
    Engine is starting and straight away is switching off. Put on diagnostic machine and the following fault codes are appering:
    18051 - Please check DTC memory of central eletric ECU.
    18353 - ???
    18358 - ???
    18045 - Data bus powertrain missing message f. central. eletric control
    18043 - Data bus powertrain missing message f. all wheel drive control
    17978 - Control Module Locked
    Cleared codes then these codes apeared:
    18058 - Data bus powertrain missing message fr. instrument panel ECU
    18045 - Data bus powertrain missing message f. central eletric control
    18043 - Data bus powertrain missing message f. air conditioning control
    18353 - ???
    17978 - control module locked
    Car was starting fine before. i was checking the fuses as the ABS light was on and a fault 00668 - Supply Voltage Terminal 30 was showing. thi fault has now gone :D but the car wont start :(
    please help.
    Thanks in advance :D
  2. a3 fkv
    a3 fkv New Member
    i also cant track online what fault codes 18353 and 18358 are if any one can help also :)
  3. NHN
    29,300
    1,702
    Does the car turn over just wont kick into life or its not even turning over?
  4. a3 fkv
    a3 fkv New Member
    cars turning over and starting instantly, but appears to immobilise.
  5. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    What diagnostic reader are you using?
  6. NHN
    29,300
    1,702
    Then thats the immo system problem then, if it kills after 2 seconds or so.
  7. a3 fkv
    a3 fkv New Member
    all it says on it is vagscanner VAGS30 can VW/Audi code reader Autel.
    its not actually mine. i borrowed it from a mate :)
  8. a3 fkv
    a3 fkv New Member
    so how do i rectify this??
  9. mike foster
    3,967
    I don't think you can without specialist equipment not available to joe public.
    If the immo. is the problem then it needs reprogramming with special ( secret) codes available only from Audi Germany or indies. with the right kit !
