Please could some one tell me....
themikeyboosh Jan 25, 2012
  1. themikeyboosh
    themikeyboosh Member
    68
    Which fuse is the tail light one, I think it's in the engine bay fuse box. Or a link to a diagram?
    2004 TDI
  2. themikeyboosh
    68
    I've managed to find my owners manual, and it's not listed in the diagram in there. I'm pulling my hair out, where is the fuse?!
  3. warren_S5
    warren_S5 Moderator Moderator VCDS Map User
    7,210
    2,487
    Inside the end of the dashboard on drivers side? Pull driver door WIDE open, then you can see dash end panel. Open end panel with flat ended screwdriver and turn panel round and 'should' have list of fuses
  4. themikeyboosh
    68
    I've looked there also but no joy. Is it listed as something other than tail light or rear light?
  5. warren_S5
    7,210
    2,487
    Not sure. Just checked my manual and no reference to rear lights. Rear brake lights are in by the battery fuse box (F29 from memory).
    I'd suggest getting a powerful torch and checking the in car fuses (if you shine fuse right at end of each fuse) you may be able to see if any are blown. Pain, but it's better than guessing! Must be in different locations in each car if it's not listed specifically.
  6. themikeyboosh
    68
    Thanks for taking the time to check, appreciated.
    I'll try that, thanks.
