Play / Rock in Drivers Seat
AudidriverA4 Dec 12, 2012
  1. AudidriverA4
    AudidriverA4 Member
    182
    Evening all,
    My A4 has a slight rock or 'give' in the drivers seat, which I find is quite annoying as it can be hard to get comfortable sometimes and the seat can sometimes make a noise going over rough roads etc.
    They are the SE seats
    I know its hard to diagnoise a problem over the internet but could it possible be a loose bolt/nut holding down the seat?
    Is there anywhere else to look for a loose bolt/Nut ?
    Anyone else come across a problem like this before in an A4?
    Also the seat also does not slide that far up and down i.e the passenger seat slides back further and forward than the drivers seat :uhm: maybe that has that something to do with it ??
    AudidriverA4
  2. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,797
    47
    does it have the electric lumber support option ?
  3. Mike B
    Mike B Well-Known Member
    1,101
    40
    could be something jammed in the runners
  4. AudidriverA4
    AudidriverA4 Member
    182
    No doesn't have electric lumber support
    yeah I checked the rails this evening and found a thick screw lodged in the rails so that sorted why the seat wasn't sliding up and down fully.
    As for the Seat itself I reckon its just worn out,
    I'm have thinking of now fitting a set of B7 Sport seats into it.
  5. benberry
    benberry Member
    37
    Mine do this in my Avant
  6. stu_m
    stu_m Well-Known Member VCDS Map User
    1,440
    mine rock a little
    I'm sure I have seen on here that its the rivets that hold the seat to the slide and the only way to sort it is to weld them!
  7. AudidriverA4
    AudidriverA4 Member
    182
    I usually drive with the radio turned up a good bit, but if I drive with the radio off, there is a good bit of noise coming off the seat, it sounds like springs squeaking aswell as rocking :keule:.
    Welding the seat actually sounds like a good idea, but I'm not the best at welding light materials :laugh:
    I think changing the seats might be the best option in my case
    Just going off topic now but SE vs Sport seats would be the most comfortable ?
  8. vr6gordy
    vr6gordy Well-Known Member
    2,763
    176
    couldnt you drill out the rivets and nut and bolt them ... or wouldnt there be room for bolt heads ????
