Plastic covers down side of car interior - how to remove?
imported_ZeroK66 May 7, 2006
  1. imported_ZeroK66
    imported_ZeroK66 Guest
    Hello all,
    In the middle of an audio install and I am stumped. I cannot get the plastic down the sides of the interior off to run cables under the carpet to the boot.
    Does anyone know how to do this? Its a facelift if that makes a difference?
    Thanks,
    Leon
  2. docurley
    4,073
    88
    You should not need to just hook it behind the carpet and pull the cables down.
  3. imported_ZeroK66
    I have a hell of a lot of cable I need run and so want to get the sill covers up to do a clean job. Anyone know how?
  4. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    They're just held on with metal clips. You need to prise up the middle and work your way to up & down as they're hooked under the corresponding trim. Removing the front side trim makes life easier. You'll then be able to run the cables through the tunnel underneath.
  5. Broken Byzan
    13,237
    466
    Is there the little screw by the rear seats on the facelift too?
    There is loads of space once the trim is out mate
  6. imported_ZeroK66
    Sorted, found the screw earlier - thanks for pointing out. You just have to pull FARKING hard it they pop up /ubbthreads/images/graemlins/smile.gif
    Thanks again
