Plasti gauge
hoffmanvp3 Oct 19, 2013
  1. hoffmanvp3
    hoffmanvp3 Active Member VCDS Map User
    304
    81
    Does any one know which colour of Plasti gauge to use for measuring your crank main and con rod clearances?
    As im getting conflicting info of Elsawin.
    [TABLE]
    [TR]
    [TD]Measuring radial clearance of conrods
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]Special tools and workshop equipment required
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]t
    [/TD]
    [TD]Plastigage
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]Procedure
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]–
    [/TD]
    [TD]Remove conrod bearing caps.
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]–
    [/TD]
    [TD]Clean bearing caps and bearing journals.
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]–
    [/TD]
    [TD]Place Plastigage onto bearing journal or into bearing shells corresponding to width of bearing.
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]–
    [/TD]
    [TD]Fit conrod bearing cap and tighten to 30 Nm. Do not rotate crankshaft.
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]–
    [/TD]
    [TD]Remove conrod bearing caps once more.
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]–
    [/TD]
    [TD]Compare width of Plastigage with measurement scale:
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]Radial clearance:
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]l
    [/TD]
    [TD]New: 0.01 ... 0.05 mm.
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]l
    [/TD]
    [TD]Wear limit: 0.12 mm.
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]–
    [/TD]
    [TD]Renew bolts for conrod bearings.
    [/TD]
    [/TR]
    [/TABLE]
    and
    [TABLE]
    [TR]
    [TD]Pistons and conrods - exploded view
    [/TD]
    [/TR]
    [/TABLE]
    [​IMG] Note
    [TABLE]
    [TR]
    [TD]Oil spray jet and pressure relief valve → Fig.
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]1 -
    [/TD]
    [TD]Piston rings
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]q
    [/TD]
    [TD]Offset gaps by 120°
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]q
    [/TD]
    [TD]Use piston ring pliers to remove and install
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]q
    [/TD]
    [TD]“TOP” must face towards piston crown
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]q
    [/TD]
    [TD]Checking ring gap → Fig.
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]q
    [/TD]
    [TD]Checking ring-to-groove clearance → Fig.
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]2 -
    [/TD]
    [TD]Piston
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]q
    [/TD]
    [TD]Checking → Fig.
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]q
    [/TD]
    [TD]Mark installation position and cylinder number
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]q
    [/TD]
    [TD]Arrow on piston crown points to pulley end
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]q
    [/TD]
    [TD]Install using piston ring clamp
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]q
    [/TD]
    [TD]Piston and cylinder dimensions → Chapter
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]3 -
    [/TD]
    [TD]Conrod
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]q
    [/TD]
    [TD]Only renew as a complete set
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]q
    [/TD]
    [TD]Mark cylinder number -B-
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]q
    [/TD]
    [TD]Installation position: Markings -A- face towards pulley end
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]q
    [/TD]
    [TD]With oil drilling for piston pin lubrication
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]4 -
    [/TD]
    [TD]Conrod bearing cap
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]q
    [/TD]
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]q
    [/TD]
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]5 -
    [/TD]
    [TD]30 Nm + 90° ([SUP]1[/SUP]/[SUB]4[/SUB] turn) further
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]q
    [/TD]
    [TD]Renew conrod bolt → Item
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]q
    [/TD]
    [TD]Lubricate threads and contact surface
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]q
    [/TD]
    [TD]To measure radial clearance, tighten to 30 Nm but do not turn further
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]6 -
    [/TD]
    [TD]Bearing shell
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]q
    [/TD]
    [TD]Upper bearing shell with oil hole for piston pin lubrication
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]q
    [/TD]
    [TD]Note installation position
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]q
    [/TD]
    [TD]Do not interchange used bearing shells (mark positions)
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]q
    [/TD]
    [TD]Ensure tight fit in retaining lugs
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]q
    [/TD]
    [TD]Axial clearance (new): 0.10 ... 0.35 mm
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]q
    [/TD]
    [TD]Axial clearance: wear limit: 0.40 mm
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]q
    [/TD]
    [TD]Measuring radial clearance → Chapter
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]7 -
    [/TD]
    [TD]Cylinder block
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]q
    [/TD]
    [TD]Checking cylinder bore → Fig.
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]q
    [/TD]
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]8 -
    [/TD]
    [TD]Conrod bolt
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]q
    [/TD]
    [TD]Renew
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]9 -
    [/TD]
    [TD]Circlip
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]10 -
    [/TD]
    [TD]Piston pin
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]q
    [/TD]
    [TD]If difficult to move, heat piston to approx. 60 °C
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]q
    [/TD]
    [TD]Remove and install using drift -VW 222 A-
    [/TD]
    [/TR]
    [/TABLE]
  2. hoffmanvp3
    304
    81
    Think i just answered my own question lol
    Plasti gauge PL-X but can some one confirm this please?
    cheers
