Plasti Dip Grill...
leeds2592 Jun 14, 2013
  1. leeds2592
    leeds2592 When I grow up, I want a 964!
    1,399
    222
    Hi all,
    I know there's a billion and one threads about what grill to get and how to replace grill etc but I couldn't find any answers to my question. I'm toying with the idea of Plasti Dip'ing my grill as I'm a bit bored with the look of my car and want a cheap mod. I was going to buy an FK grill or something but after removing my front bumper to replace the headlights, I can't be bothered with doing it all again as it was a PITA the first time!
    Anyway, I'm wanting to know how easy it'll be to remove from the little slats in the grill?
    Also, has anyone used the lacquer to create a glossy finish to the outside trim of the grill?
    Thanks in advance
  2. leeds2592
    1,399
    222
    Anyone? :(
  3. R34nel
    R34nel Active Member
    323
    33
    I did a quick 5 min job on mine the other day, check my threads, I just did the chrome surround in matte and I think I like it
  4. Bandicoot51
    Bandicoot51 Active Member
    134
    55
    Plasti-dipped the grill just for shits, used a rattle can, 5/6 coats, went onto the chrome parts really well
  5. el-diablo675
    el-diablo675 Active Member Team Dolphin Grey Audi A3 TDi
    126
    84
    I've used black bumper paint on mine came up really good finish.
  6. fps_cod
    fps_cod Member
    98
    20
    Did mine the other day. Satin black plasti-dip for the Middle, then vinyl wrapped the chrome in gloss black.
    doctor46goat and Jake 61 like this.
  7. pint-of-mustard
    pint-of-mustard Member
    Had a go with the plasti dip yesterday, really easy and im pleased with the finish. Can anyone comment on how it lasts\wears?
    SPARTAN91 likes this.
  8. Spiezels
    Spiezels Active Member
    359
    67
    Anyone got a good step by step, you just using masking tape to cover all the other areas or what?
    Nice one
  9. fps_cod
    fps_cod Member
    98
    20
    I wedged paper around the grill and masking taped it together. Doesn't really matter if you get any overspray, as you can just rub the plasti-dip off.
  10. Spiezels
    359
    67
    Oh sweet. Cheers mate
  11. Adam Wilson
    Adam Wilson Member
    95
    23
    Seems to last better than paint, plastic dip is very durable so stone chips aren't really a problem either.
  12. Mario8P
    Mario8P Active Member
    454
    133
    43
    you guys took your grill off and then plasti dipped it? or just sprayed it while on the car?
    How many coats did you apply?
  13. pint-of-mustard
    I just masked up and sprayed it on the car. I used the 1 can, probably about 5-6 coats.
    doctor46goat and Mario8P like this.
  14. Adam Wilson
    Adam Wilson Member
    95
    23
    I took it off, but I was changing my bumper aswell so made sense really. Just remember to be patient with it, the more prep work you put in the better finish you will get.
    Mario8P likes this.
  15. Tomas Sears
    Tomas Sears Member
    What prep work you guys do? Just the masking tape ect.?
  16. Bandicoot51
    134
    55
    Uhuh and remove any residue of product that might be left over
  17. Tomas Sears
    Tomas Sears Member
    OK thanks. May give it a go. Do you know if it is safe to spray the grill while on the car, even with the radiator behind?
  18. Bandicoot51
    134
    55
    Use newspaper to stuff behind the grill to protect the rad, then pull it out once completely dry. Use paper to protect a wide area around the grill as overspray is easy. Consider 2 cans so you can get at least 5 coats and maybe some sealant too which will also reduce the matt finish. Hope to see some finished pictures
  19. Tomas Sears
    Tomas Sears Member
    Decent - thanks! Couldn't decide between the Matte finish or glossy. Do you think the glossy would look better?
    The car I am planning on doing is the Audi on my profile pic
  20. Bandicoot51
    134
    55
    I've got pretty much the same car and the matte is cool however I did end up preferring the gloss look, I did the badge and chrome surrounds also, which really sets it off nice
  21. mx_rab
    mx_rab Member
    232
    17
  22. mx_rab
    mx_rab Member
    232
    17
    I plasti dipped mines. Easy afternoon job. Vinyl wrapped the chrome surround in gloss black and left the centre matte.
  23. mx_rab
    mx_rab Member
    232
    17
  24. mx_rab
    mx_rab Member
    232
    17
