Plasma - Waves on solid colour
DPM Dec 13, 2007
  1. DPM
    DPM Site Sponsor Site Sponsor
    4,969
    196
    Just wondering if anyone else with a Plasma experiences a wave effect on large areas of solid colour, usually black?
  2. Biglockie
    Biglockie Aye you know it makes sense
    1,032
    what telly you got damian?
  3. DPM
    4,969
    196
    Panasonic 37" Viera Plasma Chris
  4. Biglockie
    1,032
    I've got the 42" dude, what cables are you using to connect the source to the screen
  5. DPM
    4,969
    196
    Just a Scart for the Sky+ and components for the Xbox.
  6. AndyCollins
    AndyCollins Member
    181
    I've got the same thing on my 42" Viera. If I look closely the waves are a ghost image of whats on the built in TV tuner(freeview). Found the link below that hints at the scart cable. Seems the TV is outputting this signal from the scart socket, for example to output to a VCR if required. By using a cheap unshielded scart this signal is interfering with the signal coming in from the SKY+ box.
    http://www.digitalspy.co.uk/forums/showthread.php?t=579648
    Unfortunately I've buried all the cables in the wall, so can't replace the scart. Found the diagram for the scart on the link below so am going to open up the scart plug going into the back of the TV and disconnect the wire connected to pin 19, which is the video out signal.
    http://www.leadsdirect.co.uk/technical/scartwiring.html
    This should remove the output signal from the scart cable and remove the interference. Planning to try this later today so will let you know what happens.
  7. -Ju-
    -Ju- Well-Known Member VCDS Map User Team Panther Audi S3
    2,195
    381
    I have a 37" Viera Plasma and I must admit I've never seen interference/ghosting.
    There is a setting though in the setup menu that allows you to change the output through the AV4 scart socket, that is something that's hinted at in the link provided above
  8. AndyCollins
    AndyCollins Member
    181
    I couldn't find the setting to change the AV output, but have just disconnected the cable to pin 19 and the ghosting has completely gone. Happy with that!!
  9. DPM
    4,969
    196
    I don't have built in freeview though.
  10. Biglockie
    1,032
    Are your scarts sheilded damian?
    I know mine are thats one of the reasons I bought the ones I did
  11. DPM
    4,969
    196
    Yeah i think so but i think i'm going to buy another scart lead just to make sure. It happens worst when changing the Sky channel and you have that blue screen just before the new channel comes on.
