pirelli pzero or goodyear f1
khalil Oct 31, 2006
  1. khalil
    khalil Member
    774
    pirelli pzero or goodyear f1 which is better, the size 225 40 18, also if i upgrade my alloys from 17 to 18, what difference is it to the ride
  2. marriedblonde
    marriedblonde Active Member
    4,371
    Go for the F1's they offer the best ride/grip/wear
    Very progressive on the limit, excellant in the dry and in the wet.
    J.
  3. AndyMac
    9,832
    46
    I'd go with the F1's, the Pirelli's are softer so technically better in the dry, but the F1's are the best compromise between grip & wear and certainly cheaper as well, should be able to get 225/40/18's for around £110 a corner if you shop around. Top tip, use Black Circles to get a "fitted" quote then find out who they would use locally to fit them and then call the local place direct and save another 10-15%.
  4. leecs3
    leecs3 thinking about stuff
    604
    I've got both pirelli's (VR6) and goodyears (S3). Goodyears do have the edge in the wet/wear but the pirelli's are comfortably better in every other area.
  5. marriedblonde
    4,371
    Do you think so? I hated the relli's ono my A3. They where ok in the dry but awful in the wet. The F1's appear to have stiffer side walls, well I'm assuming they do, as the turn in is a lot cripser on the F1's, the handling's nice and progressive.
    Actually I have had them fitted to just about all my cars in one guise or a nother for years FWD, RWD, AWD. I do find them quite sensitive to tyre pressures thugh and always seem to run them higher than the standard factory pressures.
    J.
  6. SteveTDCi
    SteveTDCi Active Member
    1,407
    I had the F1's on my Focus and also have them on my XR (they cost more than the car !) I cannot fault them and would deffo reccomend them.
  7. d3fy
    d3fy Active Member
    1,412
    I had them (GSD3) on my Lexus and and will replace these Rellis on the A3 with them
  8. benw123
    benw123 Moderator
    1,863
    F1s generally get the best reviews wherever you look, but like the P-Zeros they are pricey.
    My Sportback was delivered with Bridgestone Potenza RE040s new which might be worth a look if you're looking to save money - hard wearing, fairly quiet and decent traction.
    As for ride, expect an upgrade to 18s to be a little more harsh and bit noisier but it shouldn't be too bad, because 18s are an option on all models. So whatever model you have it should cope fine.
  9. alanjonesbath
    alanjonesbath VAGOwners.co.uk
    188
    I've got the Eagle F1 GSD3's on my Ibiza FR, and they are by far the best tyre I've had, so certainly get the thumbs up from me! I'll be fitting them to the A3 as soon as I munch through the standard-fit rubber (whatever that turns out to be). The F1's seem to grip really well in all conditions, and in the wet I've never felt tyres that grippy before.
  10. steeve
    steeve Well-Known Member TeamMisano Team Ibis Audi S3
    2,713
    1,536
    I have Pirellis but will change to F1's if I keep the car long enough. The F1's are superb. Wet weather grip is just astounding.....
  11. Amchlolor
    Amchlolor Active Member
    5,604
    Another fan of F1's here.
    The only thing I can fault them on is traction (accelerating) grip in the wet.
    They do spin more readily than the Continentals I had before.
    Braking grip,lateral grip and handling (wet or dry) is fantastic though.
    I was £107 per tyre (18's).
  12. AndyMac
    9,832
    46
    "F1s generally get the best reviews wherever you look, but like the P-Zeros they are pricey."
    Don't know where you're buying your tyres but I found F1's are surprisingly cheap £107 fitted for 225/40/18's. Doubt you'll get anything radically cheaper than that for that size. On the TDi they were £65 fitted for 205/50/16's. But you do have to shop around i.e. never go to any of the high street franchises.
  13. Amchlolor
    5,604
    Even though my employer pays for my tyres,I still try to get the best deal.
    I thought £107 each was pretty damned good for F1's too.
    I expected 18" tyres to be dearer than that.
  14. Chappers
    Chappers Slowly moving forward!
    40
    10
    I'd go for the F1's, I have the 225/40/18s. Really good. It might be worthwhile having a look at a site called mytyres.co.uk. I've seen them advertised for £97 a corner delivered.
  15. synthdood
    synthdood Member
    288
    Which tyres would be the quietest? I have the factory fittes Conties at the moment, but it won't be long before they need to be replaced. I find the roadnoise is too loud and wonder if different tyres would make a significant difference.
  16. Amchlolor
    5,604
    F1's are quieter than the Contis'on most surfaces.
    The Conti's made an incredible racket really.
    God knows why they were chosen as OE.
    Actually,we all know the answer to that.
    They'll have been the lowest bidders.
  17. mfspen
    mfspen Member
    577
    10
    Interesting.
    My old 2.0TDI Sportback Sport had Dunlops, which were horrifically noisy, on any surface.
    My current 2.0T S-Line 3-door has Contis, and these are very quiet.
  18. Spin140
    Spin140 Well-Known Member
    2,196
    186
    F1's every time, I'll be doing a back to front soon so I need a full set to reaplce the Conti's.
  19. SteveTDCi
    1,407
    I've just ordered two for the Golf, grip aside I also like the looks ...
  20. Dandle
    Dandle Member
    852
    They are the old F1GSD2 the new ones look even better.
    You can see the GSD3 as fitted to mt T4.
    Have the fitted to the Audi too but dont have a pic of that.
  21. khalil
    khalil Member
    774
    so are the f1s much quiter than the perriellis,and better in genaral, theres one thing i cant understand that is why the big companys like audi / porsche etc use perrilli????
  22. marriedblonde
    4,371
    Audi will use them as they will be cheaper. Porsche don't as they don't do them in the correct sizes? Just a guess...?
  23. Dandle
    Dandle Member
    852
    Eagle F1s are the only tyre Audi use for the Q7.
    Normally car manufacturers will use several different companies for tyres so they can get the best prices possible. How well the tyre performs is second to the price when they make cars.
