Pioneer appradio and bose...Not working?
coolevilangel Mar 28, 2013
  1. coolevilangel
    coolevilangel Member
    124
    Have the appradio2 on my 59plate BE, everything works......
    However, i had the original concert hooked up last week for a few days while waiting for isolator leads coming for the alt whine and noticed a massive dif between the 2 HU
    The appradio doesnt fire up on the rear speakers.....????
    Any ideas why?
    The leads i origianlly got for it are sposed to be for the bose system...?
  2. coolevilangel
    124
  3. Nutkin
    Nutkin Member
    830
    have you plugged the rcas in for the rear. does your app radio have 3 rca outputs maybe you plugged it into the sub out by accident. or if it has 2 you might have a setting for rear speakers
  4. Sidhu88
    Sidhu88 Active Member
    808
    76
    Either that or the remote wire, blue cable?
  5. coolevilangel
    124
    the appradio has 4 rcas, 2 front, 2 back
  6. coolevilangel
    124
    Could you explain further please mate?
  7. Ash187
    7,486
    738
    It's not the cables or the remote wire.... The app radio has a funny setup. Found this same issue on Diggz car when I installed his appradio... You need to go into the options of the app radio and change the settings on the audio rear output from sub to rear speakers. If you do it while the stereo is normally on then the options should be greyed out.
    Cant remember now how it was you go into settings but a quick look in the manual will point it out
  8. Nutkin
    Nutkin Member
    830
    I meant 2 pairs. :p
    Bingo!
  9. Alfooty
    Alfooty New Member
    i have the same problem even with the setting changed as you quote the steering wheel controls work fine ?
