Pink liquid leaking
skinnyman9000 Mar 21, 2011
  1. skinnyman9000
    skinnyman9000 New Member
    22
    I've got a leak coming from the under side of the car under the engine and it's getting slowly worse. It's leaking a pink oily type fluid, but it doesn't really smell. Whats it likely to be?
  2. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,164
    1,123
    Pink.
    Coolant.
  3. skinnyman9000
    22
    Coolant reservoir is full, and the coolant is more of a orange rusty colour
  4. ScottD3
    15,164
    1,123
    I can't think what else would be pink in the engine.
  5. nwmlarge
    nwmlarge flat out
    219
    the resevoir might be rusty colour but the coolant is pink if it has been replaced in the last year.
    taste it, if its sweet its coolant if its oily its gearbox or power steering fluid.
  6. nwmlarge
    nwmlarge flat out
    219
    oh and might be washer fluid ?
  7. skinnyman9000
    22
    What colour will the power steering and gearbox oil be? They were black on my rado
  8. aragorn
    18,545
    865
    gearbox oil is pinky/red, but smells very strongly of sulphur
    PAS fluid is green if its the right stuff, but some moron could have filled it with ATF, which is red, and will kill the seals in the PAS rack...
  9. skinnyman9000
    22
    I've come to the conclusion that it's coolant. The PAS fluid is green, and has a certain smell. I decided to do the taste test on the leaked liquid. It doesn't taste sweet, but it tastes exactly the same as the stuff in the reservoir. Next question is, why isn't the reservoir level going down?
  10. hades-
    9,481
    646
    my old cat used to **** pink
    just a thought
  11. jonnycraig
    jonnycraig Member
    157
    LMFAO!
    So thats why next doors cat sits under my car!!!
  12. nwmlarge
    nwmlarge flat out
    219
    when are you checking the resevoir? just after pulling up ? the water will be at its highest level at this point.
    try it stone cold and on level ground
