Pin outs.
ScottD3 Apr 25, 2013
  1. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 saloon Team Akoya TDi
    15,166
    1,126
    I bought one of these off ebay.
    Anyone got any idea how to fit it? lol
    The plugs are about £8 from Audi and the cables are about £5 each..................there's 12 of them.
    Anyone got a pin out for it?
    I'm not buying 12 when I might need 4 lol.
  2. ScottD3
    15,166
    1,126
    Here's the pinouts for the RNS-d
  3. jb0o
    jb0o North East Forum Moderator Site Sponsor Regional Rep VCDS Map User
    2,664
    118
    Here's Elsa screendump
  4. jb0o
    2,664
    118
    I assume thats the right part, though thats only the connection for the canbus. I'll try source some more info..
  5. ScottD3
    15,166
    1,126
    Looking at that it just plugs into the Canbus system.
    No way can it be that easy for me.
    Does it have a illumination cable?
  6. jb0o
    2,664
    118
    That was just the CAN wiring. Found the extra wiring here:
    So......
    Assuming the R94 - Navigation Interface is correct the pins are as follows:
    Pin 2 - CAN-Low from Speedo (T32/19)
    Pin 3 - CAN-High from Speedo (T32/20)
    Pin 8 - Navigation CAN-Low from Navigation (T26/26)
    Pin 9 - Navigation CAN-High from Navigation (T26/13)
    Pin 6 - Positive from Radio (T8/7)
    Pin 12 - Earth
    That should do it.
    ScottD3 likes this.
  7. ScottD3
    15,166
    1,126
    I can't do the speedo side of it yet but hopefully it will work with just the navi.
    I'll give it ago when I got the parts.
    Thanks.
  8. jb0o
    2,664
    118
    Illumination will most likely come from the CAN from the Navigation.
  9. ScottD3
    15,166
    1,126
    I can't work out which is Pin1 on the 8 Pin plug on the stereo but it either Illumination or Safe.
  10. jb0o
    2,664
    118
    SAFE is the +12v perm live
  11. ScottD3
    15,166
    1,126
    O yeah.
    So it will be the illumination then.
  12. jb0o
    2,664
    118
    Nope, you don't have to tap into illumination.
    You want to connect Pin 6 of the interface to the SAFE wire (Pin 7). This is the +12v to the stereo and what will also power up the navigation interface.
  13. ScottD3
    15,166
    1,126
    I wonder why it would want a constant live.
    I assumed it would be for the illumination.
  14. jb0o
    2,664
    118
    Its just taking the same power feed from the radio to power the interface. The RNS-D shuts down on ignition and will subsequently shut the interface down too. At least that's what Elsa's telling me, haha.
  15. ScottD3
    15,166
    1,126
    haha, here's hoping.
    We'll see what happens when I plug it in. lol
    The RNS-d unit is the only Canbus item I got in the car at the moment (Apart from the TMC that don't work), so hopefully this will work.
  16. jb0o
    2,664
    118
    Hmm, be interesting to see. As the Infotainment CAN isn't setup, I've no idea if it'll work or not!
  17. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group s tronic S-line owners group
    4,054
    793
    That's for the BNS Navigation system where the directions are shown in the instrument cluster, and the navigation CD device is fitted in the boot of the car. BNS was an option on the B6 and the old A6. This won't remote control the RNS-D.
    AR-rkon likes this.
  18. ScottD3
    15,166
    1,126
    I had that fear and thought fk it, I'll give it ago, they mentioned dash and not clock.
    I'll slap in to canbus and see what happens.
    If it doesn't work I hope it lights up.
    At least I'll have something to put in to the pointless waste of space.
  19. B5NUT
    4,054
    793
    The RNS-D does not have can-bus so there is no communication between the devices.
  20. ScottD3
    15,166
    1,126
    It has canbus to the TMC and then the TMC converts the canbus signal to the clocks.
    Pins 13 and 26 on the 26pin plug is CanL and CanH.
  21. Mr K
    Mr K Member
    335
    If you put that in the hole behind the ciggy lighter, won't the buttons be upside down?
  22. ScottD3
    15,166
    1,126
    yup.
    Upside down and its a very tight fit.
    I'd also need to cut the bottom out so it clips in.
  23. ScottD3
    15,166
    1,126
    You can all start with the told you so's. :ninja:
    It don't work. lol
