Picked up my S3 this afternoon and....
gasfitter Aug 14, 2013
  1. gasfitter
    gasfitter New Member
    ..... I have say, very nice. Bit of a more solid ride than the VR6 but Ill get used to it:jump:
    noticed though that the temp sensor didnt move off of zero which was a little concerning.
    When I parked up the fan overrun went on for a short time but for all I know thats normal ; some boiler do that
    water temp sensor?
    Sandra likes this.
  2. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter
    26,639
    9,623
    Glad you got the car. Any pics for us? :) x
  3. Vex182
    Vex182 Guess what I drive...
    1,035
    79
    Welcome! Yeh temp sensor sounds about right or the thermostat stuck open possibly too, both pretty common.
    gasfitter likes this.
  4. hades-
    9,481
    646
    CTS easy to fit
  5. thegoal007
    thegoal007 Another S3 owner....
    804
    26
    common issue and nothing really to worry about. Did you road test thoroughly and it's just happened ?
  6. gasfitter
    To be honest, we went out on a 10 minute jaunt the day before. I was too busy listening for sounds to see right in front of me on the dashboard. Never had a turbo car you see:meeting:
  7. gasfitter
    Vex, is the repair in the stickies/how too's?
  8. vrbob
    vrbob Thats no Moon, Thats a space station!
    2,375
    171
    If you look to the right of the engine block you should see a pipe with a sensor mounted into it (normally a green sensor). This is the CTS you can get a replacement from the dealers for not too much money. You just pull out the retaining clip (do it with a cold engine to minimise coolant loss) and then pull out the sensor. The new one should come with a new o ring so make sure you use that and then refit.
    Thermostat isn't the hardest job in the world but is a bit fiddly due to the location. If you do want to replace it if the CTS does not fix your problem then I would recommend getting a new thermostat from the dealers again as they are a bit more expensive but much more reliable. Guides to replace can be found using the search function or via google.
  9. gasfitter
    Bob, much appreciated mate, thankyou:icon_thumright:
  10. voorhees
    voorhees Moderator Staff Member Moderator DSG
    16,149
    1,986
  11. vivalacoulter
    vivalacoulter Active Member VCDS Map User Gold Supporter Audi S5
    408
    60
    Any pics of the new car? :)
  12. gasfitter
    yea, will do this weekend
  13. Tim_Attard
    Tim_Attard Active Member
    473
    44
    temp sensor first as the thermo is a right pita, congrats on the car
  14. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,266
    360
    whilst a stuck thermostat will usually make the engine run cold it certainly wouldn't be at 0°C.... change the CTS
