Picked up my new car!
barkclark Feb 15, 2014
  1. barkclark
    barkclark Well-Known Member
    1,014
    227
  2. ruffrida
    ruffrida Well-Known Member
    1,931
    313
    Pics look pretty good dude, actually saw another set of your wheels yesterday but on a TT, the second set i have ever seen, yours been the first, didnt look as good lol
  3. barkclark
    1,014
    227
    Did you? I've never seen another set. Only seen a set on an older A4 I found online (pics further up this thread)!
  4. lowlife89
    lowlife89 Member
    193
    22
    AWESOME car dude! someone is breaking a 190hp BEX and has the 312mm up for grabs (in the classifieds section).
  5. barkclark
    1,014
    227
    Cheers man! Yeah I've already contacted him and he's going to post pictures of them at some point. I'm quite interested in them!
  6. lowlife89
    lowlife89 Member
    193
    22
    Oh, ok, didn't realize you knew :)
    BTW: what's the benefit of fitting B5 spring perches?
  7. SmoothAssault
    SmoothAssault Will design for mods
    822
    53
    More lows! (around 10mm more lows!!)
  8. barkclark
    1,014
    227
    Yeah lower on the front ~10-15mm! Evens up the stance because my car is riding high on the front haha!
  9. barkclark
    1,014
    227
    Tint vinyl was utter s**t! Tried my indicators and it wouldn't bend round the corners then done my rear light below. Looks good in the picture but wasn't so great in person so I whipped it back off! No loss for £1.97 haha!
    EDIT: I think it looks great in the picture, a little dark though! Maybe try out some tinting spray next!
  10. lowlife89
    lowlife89 Member
    193
    22
    Ah I see :) the front being higher than the back is OK, this shifts some of the weight to the back and is good IMO for nose-heavy, understeering FWD A4s such as ours :)
    Anyway, glad you have good roads to ride low :arco:
  11. barkclark
    1,014
    227
    The roads still aren't great haha. So I'm only lowering the rear 10mm and the front ~20mm and keeping comfortable 235/40 tyres on 18's :D
    No crazy lows or massive wheels. I must be getting old haha!
    ruffrida likes this.
  12. barkclark
    1,014
    227
    I've noticed the links for the pictures from a few posts ago have broke, so I've re-uploaded some of them! Should receive my new front 312mm set-up and rear disc and pads this week :D!
  13. peteh
    peteh Member
    46
    Looks good mate, I picked some s4 rims up sat from up near Perth, nice drive up from edinburgh.
    Quick question, how are you going to lower it that way, b5 perches on standard sport suspension for the front and springs on the rear?
  14. barkclark
    1,014
    227
    Cheers man. I quite like the S4 wheels! Eibach Pro springs all round with the B5 perches on the front mate! Front will lower approximately 20mm dependant on how my car take to the eibachs and b5 perches as it can vary a little bit.
  15. barkclark
    1,014
    227
    Tint or no tint?
  16. ruffrida
    1,931
    313
    QUOTE=barkclark;2190063]Tint or no tint?
    View attachment 34934 [/QUOTE]
    Having this debate me self. Think it looks really good on the right colour car like yours,with mine been black in not quite sure
  17. louis_123
    louis_123 Active Member
    197
    37
    Tint :) may do this to mine aswell :)
  18. Martyn_V6
    Martyn_V6 Member
    41
    No tint for me
  19. barkclark
    1,014
    227
    Not much been happening here for a while. Car has just been serviced and a new front drivers side wheel bearing has been fitted. Gave it a full clean the other day so here is a quick picture outside work of the cleanzz.
  20. norris_309
    norris_309 Member Audi A4 Audi Avant Owner Group
    266
    24
    Cars looking spot on.
    You're cracking on with sorting it, unlike me!
    When I bought mine I needed to change headlight switch, replace 1 or possibly 2 rear parking sensors and I've done none of those!
    Instead, I've had to replace the front pads as they were cheap tat that was knocking a lot.. But before I realised it was that I replaced a shot looking front control arm which didnt fix the knock obviously!!!, then drivers window regulator went.
    Now the airbag light is on,...
    First up though, I'm going to get the cambelt done, that's nearly 4 years old.
    Cars....gotta love um
    I see you've debadged the rear, mine was already done, I was actually toying with getting some to put back on. Not sure though
    barkclark likes this.
  21. barkclark
    1,014
    227
    Cheers man! Don't worry mate I have a long list too! Two rear shockers, 4 wheel alignment, bigger brakes upfront and new discs & pads on the rear to be fitted. New CTS and thermostat. Think I might have an oil leak too... My car was also already debadged when I got it!
  22. norris_309
    266
    24
    That reminds me, my pd130 mk4 golf isn't holding the temp like it should now too... Looks like that may need as new temp sensor!
  23. barkclark
    1,014
    227
    Yeah mate either that or the thermostat. Mine never rises above 70!
  24. ruffrida
    1,931
    313
    Defo 1 of the 2 bud
  25. lowlife89
    lowlife89 Member
    193
    22
    Doesn't rise above 70 Celsius (on a mid-long run)? I don't think that's right.. as long as it's not below 0, it should get to 90" Celsius after 2-3miles!
    I myself am almost out of the "**** never ends" club after replacing belts+water pump, all of my dampers+springs, entire front suspension + rear stabilizer bar links and bushings, B7 320mm discs+pads+calipers..
  26. norris_309
    266
    24
    Mine gets to 90 after about 5 miles or so, then will drop down on occasion & bob back up.
    Car still runs fine & mpg is still OK.
    Lowlife... Sounds like you've been having fun with all that!! Must be like a new car now... Nearly the cost of one too I bet!
    I'm dreaded mot time with both my cars!
    After changing the front lower front control arm I noticed most of the rubbers are showing their age now!!!! And my golf had a few suspension related advisories last year....
  27. ruffrida
    1,931
    313
    All temp gauges should get to 90 and stay there, up and down is usually the thermostat is stuck open.
  28. lowlife89
    lowlife89 Member
    193
    22
    For sure, I changed everything shortly after getting it (labor is pretty cheap here compared to the UK) and MAN it feels like a new car. What's worth mentioning (this is something I've read online and makes sense to me) is that the durability of a part (shock absorber, control arm, bushing, link) depends on the other parts' state.. bad shock absorbers will drain the life out of your new expensive Lemforder/TRW control arms quicker.
    ruffrida: I want to add that low coolant levels can also have this effect if you're in a cold climate (if you're in Miami I don't think it would drop below 120 :D). It happened on my other car (which doesn't have a low coolant level warning, I think the B6 does).. if your temp is fluctuating and your heating doesn't work properly, this can definitely be part of the problem.
  29. barkclark
    1,014
    227
    Nice and sunny at 6:30am this morning!
  30. ruffrida
    1,931
    313
    yeh know where you coming from but be warned that the coolant sensor on the B6 will only go of at very min level, and i mean you can only just see it in the bottom of the bottle
  31. s4iloveyou
    s4iloveyou New Member
  32. barkclark
    1,014
    227
  33. barkclark
    1,014
    227
    First 10,000 miles done! Great car!
  34. barkclark
    1,014
    227
    Would be nice to clock in these miles when this tank is empty! Literally couldn't fit anymore diesel into it!
  35. barkclark
    1,014
    227
    Merry Christmas! [​IMG]
  36. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    Tint.... I used plasti-dip on mine.
  37. barkclark
    1,014
    227
    A little bored day off work project. Just to see if I like it or not haha.
  38. barkclark
    1,014
    227
    Done!
    [​IMG][​IMG]
    Not sure if I'm 100% for it but I'll do the rest and live with it for a while and see how I like it!
  39. ruffrida
    1,931
    313
    Really need to get mine done, makes it look so much tidier,
  40. BakPak
    BakPak No Gear
    957
    137
    43
    Looks good bud. Did all mine last Xmas with carbon vinyl wrap. Enjoyed doing it too lol!
