Phone prep help
beerglass Jan 19, 2007
  1. beerglass
    beerglass Member
    233
    Using the multi function wheel and built in bluetooth phone prep and having a few problems.
    The phone syncs up ok via bluetooth ( nokia n73 ) and I can make phone calls via the bluetooth system.
    The buttom on the left next to the track select should list the phone book entries. But when I press this I get "function/buttom not allow"
    I have spoken with audi services and they said to copy all my phone book entries onto the sim card and not the phone itself.
    Done this and still no joy.
    Reading the manual its supposed to work
    Anyone comes across this problem before?
  2. s8craig
    1,750
    55
    Yes, the N73 is Symbian OS and not supported by the Audi module except for Hands free, all the extended commands (AT) that Audi use are not in the SYmbian OS of the N73, this applies to all N & E series phones from Nokia.
  3. Vertigo1
    Vertigo1 Well-Known Member
    3,381
    541
    Can confirm this, the N-series phones from Nokia are a nightmare and all you'll get is basic functionality with none of the phonebook or call list sync. Furthermore, some of them can't even hold a bluetooth connection and keep disconnecting, notably the N80.
    This is down to Nokia & Symbian rather than Audi btw.
  4. wilko
    wilko Top Gear
    725
    I read somewhere there was an upgrade to the Bluetooth software on the device to include the new phones. It could be worth havng a word with your dealer to see if there is a software upgrade available to support you new(ish) fone.
  5. s8craig
    1,750
    55
    None of the A3/A4 phone modules are upgradeable. Only A6/A8/Q7 modules can be updated. Trust me your N series phone is a no go with a MFSW and audi BT kit.
  6. Vertigo1
    3,381
    541
    As I said, this is down to Nokia & Symbian rather than Audi. Symbian's OS doesn't support the extended AT commands used to retrieve the phonebook and call lists, despite them being a virtual industry standard, and Nokia have worked their usual new-phone-firmware magic to produce a dodgy BT connection on some models.
