Phone cradles....
Kriminal May 31, 2010
  1. Kriminal
    Kriminal Member
    176
    Just a quick question : how are phone cradles attached to the A3 ?
    I'm looking at one at present, and it seems to be fitting flush to the dash (to the bottom left of the vents). It says in the description that it's "GSM Mobile Telephone Preparation".
    The thing is, I wouldn't want it, but am concerned that there may be a couple of gaping holes left
  2. 347
    347 Active Member Team Daytona VCDS Map User Audi S3 DSG
    362
    59
    you concerns are correct , behind the front cradle mounting plate bracket is a threaded fixing plate inside of the dash , so you remove the cradle and will be left with a nice big 40mm wide 70mm high hole , i have covered the hole with a carbon fibre plate and s line badge
  3. Kriminal
    Kriminal Member
    176
    Ouch! That sounds like one huge hole to be left with.
    Thanks for letting me know :thumbsup:
  4. RAF_S7
    RAF_S7 Well-Known Member Team V8 Gold Supporter Team Sepang A7 Owner Group Black Edition Audi S7
    1,077
    598
    If you order an SE model, you can specify the cradle inside the centre arm rest, underneath a lid:o.k:
    Also, I thought there was an option now for Bluetooth only (no cradle option) I'm sure someone will update this thread.
  5. Kriminal
    Kriminal Member
    176
    Thanks for the heads-up, but I think I should've pointed out - I'll be buying second hand.
    The car was on an Audi dealership website (the one with the cradle).
    Strangely enough, the car was sold/removed from the site the following day. Something tells me I wasn't supposed to have it. :laugh: <sigh>
  6. c_w
    c_w Well-Known Member
    1,163
    87
    When I was looking I specifically would not have bought one with this cradle fitted, it looks terrible and could attract unwanted attention - though I hate added any gizmoes/clutter inside a car, especially something that leaves holes in the dash. The car I bought had a Parrot bluetooth kit fitted and this was stuck to the dash between the centre vents and speedo clocks. However, I made sure it was only a temporary fix (was just velcro) and after I boght the car I moved it to the ashtray so it is hidden.
  7. beanoir
    beanoir Large Member
    2,171
    31
    I have a Tom Tom cradle with my iPhone, just a sucker on the window, connected bluetooth for handsfree, and aux to the back of the headunit for music, DAB, movies, TV etc etc..
    I've tidied the cables a bit better since, but here is a pic..
  8. S3RYE
    S3RYE Interior Next!!
    3,448
    70
    with the BT phone prep i think you get a choice when ordering, bluetooth phone prep low or high... low being centre arm rest, high bein dash mounted (this is what i thought anyway)
  9. beanoir
    2,171
    31
    Correct!
