Phatbox protective cover
chrisn900 Oct 27, 2009
  1. chrisn900
    chrisn900 Member
    78
    I've installed the phatbox into my boot space.
    Everything is fine and working properly.
    I'd like to mount some sort of protective cover over the unit to protect it from damage etc.
    Has anyone any suggestions as to what I could use ? (carper or car mat)
    I'd need something about 18'' by 12'' I think.
    Thanks for any suggestions : )
  2. mattyboy199
    mattyboy199 Well-Known Member
    1,890
    29
    some sort of games console carrier case ?
  3. kite
    kite Member VCDS Map User
    677
    Be careful about covering, you don't want the unit overheating.
  4. chrisn900
    chrisn900 Member
    78
    it would just be a fairly loose covering, open at sides
    just wanted something to cover the unit and give mild protection from damage
    i'm thinking velcro and grey material of some sort,i'll keep thinking
    Thanks for suggestions :)
  5. dunk
    dunk Member
    770
    the phatbox aluminium case is not a heatsink - its fake.
    the electronics inside couldnt keep a mosquito warm let alone overheat so cover it with anything you think looks ok.
    not sure why thoug? its in a thick aluminium case so unlikely to get damaged apart from scratches (unless you have taken it out of its case altogether?)
  6. Essflee
    Essflee Well-Known Member
    2,154
    67
    Yup, mines been in the boot in this and my old car with all sorts of junk in the past and has never had any issues, to save it floating around in the boot i've just cable tied it to one of the buckles in the corners designed for the cargo net...
  7. RS84
    RS84 R15 - TDI Power
    168
    How high did you mount the unit?
    Just get a cargo net. That's what I did, now nothing moves around in the boot.
