Phatbox info please.
doeboy May 6, 2006
  1. doeboy
    doeboy Member
    602
    Can someone post details/links about phatbox please.
    I've done a google uk search which didn't come up with much, are they us imports?
    Secondly i'd like to know how you can navigate 4000+ songs using a 1 line display, sound like it would be impossible.
  2. AndyM
    AndyM Member
    156
    You can get UK versions of the units however importing it from one of the US ebay sellers is usually the cheapest method at around £140 (mikanmotors is recommended).
    Simply put, for navigating your tracks, it takes the place of a 6 disk changer, cd1= tracks, cd2=albums, cd3=genre, cd4=artists etc when you change to one of those cds you can use the left and right button to change through the options, the result is read back to you by a voice prompt from the Audi headunit. After 5 seconds it defaults back to cd1 so you can use left and right to change tracks in the playmode you've picked.
    Works very well with the limited functionality of std Audi headunits
    I believe theres a demo on the phatnoise website
  3. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator Team V6 TFSI Owners Group Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,092
    2,541
    You could try sending a PM to RasA4. He has one fitted in his car.
  4. AndyM
    AndyM Member
    156
    This is the link to the flash demo, should explain it pretty well for you Demo
    Also worth considering is looking at Phathack which allows you to fit larger than the std 20GB hard drive to the unit, was one of the first things I did after installing mine /ubbthreads/images/graemlins/cool.gif
  5. dickys3
    2,954
    [ QUOTE ]
    [/ QUOTE ]
    I got mine from mikanmotors and the service was excellent.
    As for the phatnoise, excellent bit of kit!
  6. ButchsTT
    ButchsTT Member
    69
    i have had mine for about 1 yr love it I have it in My Audi Tt roadster only problem if you want to call it that was I had to modify the little door that the cd changer sit behind no major deal the other is how fast you can fill one up I have a 20gig but I bought a 100 gig drive from e-bay and have changed it so right now I have loads of space love it everyone should get one
  7. mattyboy199
    mattyboy199 Well-Known Member
    1,885
    Pretty excellant i ve found wasnt to sure when intialliy reading about it but bought one anyway & found it to be spot on especially considering non of these stereos were designed to have this connected it was purely an after thought which works great. Who needs an ipod ? who wants to fath around using an ipod while driving when you can simply go through your stereo.
    Simply press the scan button & the system will tell you what your listening to.
    Now go buy one ;-)
  8. MarcQuinlivan
    MarcQuinlivan Active Member
    2,539
  9. MarcQuinlivan
    2,539
  10. giblets46
    giblets46 Member
    156
    If you can keep us updated on the phatnoise with the Concert/ symphony III it would be most appreciated.
    Edward
  11. MarcQuinlivan
    2,539
  12. giblets46
    giblets46 Member
    156
    I have a VW golf Mk5 with the RCD300, which has a quadlock on the back,
    the phatnoise worked fine with this (have heard rumours it is the same stereo as the concertIII, it certainly looks the same), the part numbers from VW i needed were:
    £28.09 Cable 1J0051592A
    £8.99 Adaptor 1J0051445D
    No promises to if they work or not, there is a picture of the RCD300 quadlock here if you can compare if it looks right:
    http://www.golf5-sound.de/Quadlock.jpg
    the
    Toureg quadlock is here:
    http://www.tm-techmark.com/touareg/audioonlyinstall.htm
  13. MarcQuinlivan
    2,539
  14. giblets46
    giblets46 Member
    156
    Just done some research, the adaptors look identical to the VW quadlock (just found some concert III pictures on ebay). This should mean that if you get the leads suggested earlier, then you should be able to connect it up(that is on the assumption that VW phatbox's and Audi ones are the same), though clearly its a case of caveat emptor!. Interestingly, it also appears to have Aux plugs, so you can plug in an auxilary input too.
    The back of the RCD300
    The quadlock and wiring diagram on the Concert III
  15. MarcQuinlivan
    2,539
  16. 4Ring Jelly
    4Ring Jelly Member
    41
    what are the dimensions of the phatbox??
  17. MarcQuinlivan
    2,539
  18. leecs3
    leecs3 thinking about stuff
    604
    got a link to his ebay shop?
  19. MarcQuinlivan
    2,539
  20. MarcQuinlivan
    2,539
  21. giblets46
    giblets46 Member
    156
    If that fails, try VW dealers,and see if that adaptor fits into the quadlock, am sure if you speak to them they may let you trial it without paying.
    Would offer for you to try my adaptor thats in my golf but you appear to be in Ireland so a bit difficult!
  22. MarcQuinlivan
    2,539
  23. marmite
    marmite Counting the Tesco Club points
    1,101
    I have got the phatnoise and had it 3.5 years now
    It is very easy to use in the car and very easy software to load the music on with
    Takes some time to get the hang of though...but you hen start remembering discs numbers
    You can upgrade the hard drive in it to...there is a link somewhere on how to do it
    Natedog got one from US really cheap
  24. giblets46
    giblets46 Member
    156
    Hi Marc, any updateonthe cables for your Concert II/ headunit?
    cheers
    Edward
  25. MarcQuinlivan
    2,539
  26. giblets46
    giblets46 Member
    156
    Hi there, marc, have you sorted this out fully and got it working, or been givent he correct cable no for it?
    Edward
  27. MarcQuinlivan
    2,539
  28. giblets46
    giblets46 Member
    156
    That one then! :) Many thanks for updating us on that, sure there will be plenty of people who will find it usefull! Is the cable long enough? Where did you end up installing yours?
    Any pics would be appreciated!
  29. MarcQuinlivan
    2,539
  30. giblets46
    giblets46 Member
    156
    Am guessingit may well be down to price then! Was wondering, does your DIS display any extra track info? Or do you still just get track numbers?
    cheers
  31. MarcQuinlivan
    2,539
  32. giblets46
    giblets46 Member
    156
    The CD changer lead that AUDI recomends is a different code to the VW one, so will get whichever is cheapest! as they will both connect the phatnoise to the adaptor!
    STILL not heard when i am getting mine, apparently its on the country though!
  33. MarcQuinlivan
    2,539
  34. giblets46
    giblets46 Member
    156
    Thanks, thats fantastic, looks a lot like my Golf install, I may try and do what i did with my golf which is to slide the cables along the top of the glove box instead of removing it. MY big question was of course who to remove the headunit, which you have answered, the boot looks very complicated. YOu think there ouwld be space under the passenger seat?
    MANY thanks
    Edward
  35. MarcQuinlivan
    2,539
  36. Lowlife
    Lowlife German Hardcore
    568
    Is it possible to fit phatnoise into a pre-facelift A4? Have only seen it on later models...
  37. MarcQuinlivan
    2,539
  38. Lowlife
    568
    Not a clue! its a 97 r-reg if that helps, it has a concert HU thats a little longer than single din...
  39. timps
    timps Shakersville
    235
    The concert HU (picture below) on a B5 is compatible with Phatnoise
  40. giblets46
    giblets46 Member
    156
    Juat installed my Phatnoise today, many thanks to Marcs excellent guide, though needless to say Audi's don't like being taken apart! (lots of cuts!).
    Managed to get the cable on top of the glove box with a coat hanger and only undoing the top screws on the glove box, but the side sills were the worst part, with several of the clips pulling out of the plastic and firmly embeded in the bodywork, and a couple of others the plastic gave way. A note that inthe sport back, the sill from front to back is in one long piece.
    In the boot, i managed to just pass the cable out of the side instead of though the coat hook area, and saved me having to take all the boot out!
    But...relieved i have got it out of the way! :)
