Just to clarify, do you need an ignition feed or a permanent live, as the boost gauge only works with the engine running, I assume you would need an ignition feed?? Also does the gauge have illumination? as you will need a sidelight feed for that!
I need a permanent and ignition live for the gauge. But I already got the ignition wire. Just wondering if there is permanent live available from the fuse box.
There's lots of live wires in the fusebox, I would break into a thick red coming out of the fusebox, use a line fuse holder with a 2/3 amp fuse & run it to the gauge!
