Pennies in the ashtray...
Louis Cronin May 26, 2010
  1. Louis Cronin
    Louis Cronin Member
    67
    Hello,
    I have a slight problem with my Alarm, it goes off when it wants to, checked the siren and thats fine. Fault code is saying interior monitor is setting off the alarm. The garage i bought it off have said that this is a 'common' fault with A4 cabs and Audi have said it can be caused by pennies being in the ashtray and around that area, armrest etc...
    Is this bull?
  2. drewbee
    drewbee Member
    196
    yeah sounds bull to me!
    i dont get that problem and mines full of POUNDS!! hahaa
  3. simon.m
    simon.m Active Member
    2,747
    ha where do some of these ppl come from what a load of rubish
  4. Broken Byzan
    13,237
    465
    What a load of horse **** !
    Nice excuse tho, i like it !!
    Seriously, if you can get the code read it will tell you what sensor caused the alarm to go off
  5. Louis Cronin
    Louis Cronin Member
    67
    i have posted a scan in the Vag com forum, i will copy and paste over here
  6. Louis Cronin
    Louis Cronin Member
    67
    Address 45: Inter. Monitor Labels: 8E0-951-177.LBL
    Controller: 8H0 951 178
    Component: Innenraumueberw. 0211
    Coding: 00001
    Shop #: WSC 00000
    4 Faults Found:
    01350 - Alarm via Theft Warning System; Rear
    43-00 - Closed
    81-00 - Open
    01349 - Alarm via Theft Warning System; Front
    43-00 - Closed
    01838 - Transceiver Module 2 for Interior Monitoring (G305)
    27-10 - Implausible Signal - Intermittent
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.LBL
    Controller: 8H0 959 433 D
    Component: Komfortgerát T3B 1210
    Coding: 06795
    Shop #: WSC 00672
    3 Faults Found:
    01616 - Signal Wire to Interior Monitor
    49-10 - No Communications - Intermittent
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01331 - Door Control Module; Driver Side (J386)
    80-10 - Single-Wire Operation - Intermittent
  7. Broken Byzan
    13,237
    465
    Thats the one i would be concerned with, more likely a sensor breaking down, especially when the other module concurs
    35-00 - -
