Pedal Box - Whats this then?
ABYSS Jan 11, 2012
  1. ABYSS
    ABYSS Andrew - Diesel Tuning UK Site Sponsor Black Edition S3 Saloon Team Ara Blue
    940
    524
    93
    Diesel Tuning UK would like to introduce the Pedal Box to the UK market from DTE of Germany. A simple yet effective throttle response modification designed to improve your driving experience. Fitting between the accelerator pedal and the ECU (the cars brain), on modern ‘drive-by-wire’ vehicles, the Pedal Box maximises the signal to give the smoothest and most effective response. Suited to both diesel and petrol vehicles the Pedal Box makes the vehicle more driveable in many ways...
    Overtaking
    When in an overtaking situation it is essential to access all the engines power as efficiently as possible. An enhanced throttle response improves that efficiency and therefore the speed and safety of an overtaking manoeuvre.
    Driving Pleasure
    A better throttle response plays a major part in the overall driving experience as it gives the driver superior control over the acceleration of the vehicle.
    Coming Out of a Corner
    Prior to entering a corner, the vehicles brakes are applied or power is reduced. When the accelerator is applied through or after the corner, the vehicle needs to respond smoothly and quickly in order to maintain the correct road speed. A better throttle response improves the power delivery and helps the car accelerate from the corner more effectively.
    Changing Gear
    After changing gear there can be a slight delay in the response of the throttle, this delay is often only one or two seconds but can have a negative impact on the driveability of the vehicle. An improved throttle response will vastly shorten or remove this delay altogether transforming the driving experience.
    Traditionally a vehicles accelerator pedal would be connected to the engine by a cable, so that when the pedal was pressed the cable would be pulled and the throttle would open. Most modern vehicles utilise a fly-by-wire control system for the accelerator. This means that when the pedal is pressed a sensor measures how far the pedal has been pressed, sends a signal to a control module, which in turn sends a signal to the engine to open the throttle the corresponding amount.
    The Pedal Box sits between the sensor and the control module, intercepting that signal and altering it in order to shorten and improve the response time. This works in the same manner as many manufacturer fitted ‘Sport’ buttons, reducing the amount of pedal travel required to achieve ‘Throttle Wide Open’, allowing you to access the engines full potential.
    The Pedal Box comes programmed with four adjustable maps, specific to your vehicle model, that each alters the throttle signal to a different level. The driver can select and adjust the different maps to find the setting that best suits their driving style and individual vehicle.
    No additional power, no additional stress on components, just better response.
    rrp is £229.00 inc vat but we will be offering ASN members discounts on the Pedal Box too
