PDR (Paintless Dent Removal) Possible on this?
essIII Sep 17, 2012
  1. essIII
    essIII Active Member
    285
    35
    All,
    I've had this dent on the roof of my S3 for too long now! I'd kind of written it off as too expensive to bother repairing, but it does make me cry a little each time I was the car! Having read a bit about PDR recently, I was wondering if anyone with any experience thought it might be possible to remove this one?
    (right in the middle of 2nd pic, harder to spot)
    Cheers,
    Rich
  2. hades-
    9,481
    646
    looks like a good PDR guy could sort that
  3. MattyW19
    MattyW19 Member
    401
    I would of thought so! I had my door done after some sod had opened the door on it!!
    However they used bars with mine and got to it down the window. They will probably use a suction on that to be honest?
  4. essIII
    285
    35
    Yeah, it's the 'sharpness' of the dent that worries me - if you look at the 2nd picture there's almost a straight line crease along the bottom of it - I thought that might rule out suction?
  5. MattyW19
    MattyW19 Member
    401
    Yeah I know what you mean! Your probably best taking it to them and see what they think? I'd definetly have it done even if there is the slightest marking left?
  6. OVRA3
    OVRA3 Well-Known Member
    1,079
    80
    I think they would use a glue on it to effectively pull it out the over pull it then tap back with a little hammer thing all very clever most companies have an email contact send a pic to them
  7. tedward
    tedward Member
    166
    All depends on the skill of the PDR guy and whats behind the dent....it may lie exactly over a roof support cross section making access difficult/impossible.
    When access is difficult they can use glue on dent pullers to get the ball rolling. May be a case of they can make it better, but not perfect.
    Where abouts in the country are you? i know a PDR guy who is second to none.
  8. essIII
    285
    35
    Surrey - no where near Lancashire! Read a few good things about these guys so will shoot them a mail: Dentex Mobile Paintless Dent Removal 19 Yrs Experience Free Online Estimates
  9. icekay
    icekay Member
    79
    As long is the panel is not double skinned and they can access behind the dent they can do it, bearing In mind if the crease is sharp or quite deep it will probably crack the paint work.
    Best bet is take a picture and email/upload to a few PDR companies and see what they say.
  10. PaulRS3
    PaulRS3 Well-Known Member
    1,211
    143
    I had a similar dent removed on my previous S3 after a conker fell on the roof, while waiting at a junction.
    I could not tell afterwards.
    All depends on the skills of the operator and where the support braces fall.
  11. _G_
    _G_ Active Member
    876
    the clear coat may be damaged - agreed.
  12. yoshia3aportback
    yoshia3aportback New Member
    i always think its hard to tell with pictures of dents for PDR the slight crease shouldnt be much of a problem for decent PDR guys. i have seen our local guy in aberdeen remove some dents that i did not think would be poissible but you would never notice the difference afterwards.
  13. PH1L
    PH1L Gievf Buckets
    3,851
    40
    it would take a skilled pdr but its entirely possible if youre down dundee way theres a very good lad
  14. Forbzeeee
    Forbzeeee Well-Known Member VCDS Map User Team Sepang Audi S3
    869
    363
    I used to run my own business doing PDR and this certainly looks doable. PDR would be your best option. I used to take on any job where the paint was not cracked but every single ding/dent is different. It would have to be looked at by eye to tell if it will be removed completely or if there would be a tiny crease left as metal has memory.
    All I can say is that it will look much better and would be well worth the cost of a PDR technician coming to look at it and take it on.
  15. karl210
    karl210 Member
    324
    chipsaway do a free quote, ask for one of thier pdr guys it might cost peanuts, my mate works for them but he does manchester area.
    i saw a thing on youtube the other day where you heat up the dent with a heatgun and then spray it with compressed air and it can bring the dint out, worth a look
