Pd 170 tdi fault code help pleas
ash101 Apr 3, 2011
  1. ash101
    ash101 New Member
    Hi I have a 2007 pd 170 and the cel light has come on Iv reset it but after about 20 miles it comes back on iv scanned it with vag com and these faults come up.
    Can someone shed a bit of light on whats going on
    Address 01: Engine Labels: REDIR FAIL!
    Control Module Part Number: 03G 906 018 DT HW: 03G 906 018 DT
    Component and/or Version: R4 2.0l PPD1.2 G 0431
    Software Coding: 0050072
    Work Shop Code: WSC 66565 257 00032
    4 Faults Found:
    000257 - Mass Air Flow Sensor (G70): Implausible Signal
    P0101 - 006 - Short to Plus - Intermittent - MIL ON
    Freeze Frame:
    Fault Status: 10100001
    Fault Priority: 1
    Fault Frequency: 5
    Reset counter: 40
    Mileage: 61904 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 12:57:20
    Freeze Frame:
    RPM: 1568 /min
    Torque: 0.0 Nm
    Speed: 82.0 km/h
    Temperature: 15.0°C
    Pressure: 1107.6 mbar
    Text: 0
    Text: kg/h
    000258 - Mass Air Flow Sensor (G70): Signal too Low
    P0102 - 007 - Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00000010
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 39
    Mileage: 61906 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 12:59:29
    Freeze Frame:
    Text:
    Torque: 40.0 Nm
    Speed: 0.0 km/h
    0.00 %
    Voltage: 13.90 V
    Mass Air / Rev.: 277.9 mg/str
    Mass Air / Rev.: 0.0 mg/str
    001026 - EGR System: Excessive Flow
    P0402 - 006 - Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 1
    Fault Frequency: 2
    Reset counter: 40
    Mileage: 61959 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 17:37:14
    Freeze Frame:
    RPM: 1952 /min
    Torque: 96.0 Nm
    Speed: 103.0 km/h
    0.00 %
    95.55 %
    Mass Air / Rev.: 403.3 mg/str
    000579 - Solenoid Valve for Boost Pressure Control (N75): Malfunction
    P0243 - 009 - Open or Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00000100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 39
    Mileage: 61953 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 15:43:16
    Freeze Frame:
    RPM: 736 /min
    Torque: 32.0 Nm
    Speed: 0.0 km/h
    0.00 %
    Voltage: 13.90 V
    Pressure: 1043.7 mbar
    Pressure: 979.8 mbar
    Readiness: N/A
    Any advise would be apreicated
    cheers ash101
