PCV mod help please!
Keith_S3 May 11, 2009
  1. Keith_S3
    Keith_S3 Member
    62
    Hi all been reading up on any posts i can find about this, and have found the link to a part that has been made for this purpose.
    my question is this is not how jonny c did his and i see a few others have this listed as a mod on there posts, can anyone tell me what's required to do it jonny c's way and are there any ill effect's caused by it.
    Thanks Keith
  2. mhill
    mhill Member
    323
    WTF? Sorry i cant be of any help just a little intregued as to wht this mod is?
  3. Iggu
    Iggu Active Member
    1,229
  4. wolfbane1967
    wolfbane1967 Member
    237
    9
    Whats the part nr for the stop end you put at the forge hose?
    Cant find it at forge site
  5. dc240969
    dc240969 Member VCDS Map User
    925
  6. Fast,not furious
    Fast,not furious Dealing with an OCD
    416
  7. block
    block Member
    255
  8. Fast,not furious
    416
    mmm,it worked when i posted it!
    Ok,i found the part on Forge,try this link now:
    Hhttp://www.forgemotorsport.co.uk/content.asp?inc=product&cat=&product=FMTB052K
  9. wolfbane1967
    wolfbane1967 Member
    237
    9
    Thank you for the link
  10. Keith_S3
    Keith_S3 Member
    62
    Brillant thankyou,
    now the all important question for fast not furious,
    as some one other than jonny c, have you ever noticed any difference with this carried out?
    and thanks again
    Keith
  11. Fast,not furious
    416
    Erm - no. I still think it's a worthwhile mod though,especially for the minimal outlaw,and safety factor:
    "The PCV opens and vents oil vapour into the the inlet manifold where it's then burnt off in the engine. This is done to control emissions. Used engine oil going back into the engine ain't a good thing.
    If the PCV fails the result can be increased pressure in the manifold resulting the engine oil cap being blown off by the pressure. With this modification all boost is kept in the inlet manifold and fed back into the system rather than the PCV venting boost which can be anything up to 4psi.
    This isn't really approved of as technically you are venting oil vapour into the atmosphere and therefore flouting emissions laws but it's such a tiny amount that yo won't ever be able to tell the difference"
  12. Keith_S3
    Keith_S3 Member
    62
    Thank's the reason im looking into this is that like jonny c said somewhere, sometimes i feel the car is not as responsive as others just at random times it will feel much quicker than others!
