pathetic horn
olds_kool Jun 13, 2008
  1. olds_kool
    olds_kool Active Member VCDS Map User
    1,094
    15
    had to sound my horn this morning cos a transit nearly took my front end off when he didnt notice me on his inside on a roundabout, good job my brakes work cos my horn is pathetic, made a friendly poop poop noise, checked my earlier car and it makes a loud aggresive beep beep noise
    is it a facelift 'improvement' or is my horn knackered
  2. ALPINE
    3,093
    LMAO my horn sounds so Gay! its that quiet it cant be heard inside another car.
  3. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,776
    33
    There are two horns, a high and a low.
    I had the same thing recently. Turns out the low horn (the loud one) had been fitted upside down and must have got filled with water when I had my last engine pull. I suspect when the garage was removing the pump from the waterbottle it must have leaked some in.
    When I took my horn out, it was obvious it was knackered as it rattled and was full of sh1t. Pick one up cheap as chips from a breakers.
  4. Fraser
    Fraser Member
    584
    make sure both are plugged in, i took mine for a cambelt and waterpump change and one was left unplugged
  5. olds_kool
    1,094
    15
    sounds like thats the problem, suppose bumper will have to come off, it takes forever to get it to fit back on properly
  6. Fraser
    Fraser Member
    584
    plugs are behind the lower drivers side bumper grilles so you should not have to have the bumper off.
  7. Oranoco
    Oranoco Well-Known Member
    3,998
    408
  8. olds_kool
    1,094
    15
    ha ha thats more like it
  9. Turbo Lag FTW
    Turbo Lag FTW Hate those none insured you know who types
    235
    seen the vid where the guy does it to a cop, he was very keen lol
  10. Z82
    Z82 Member
    454
    When one of mine went I used the horn from my old coupe and got access via the wheel arch by gently bending the inner arch out of my way...
    OK I cheated, I just tie-wrapped the coupe horn to the old horn and did the connections through the arch. Think I had to alter the connections though cos that was 2yrs ago now.
