Passenger side brake light problem
richardshoes Feb 25, 2013
  1. richardshoes
    richardshoes New Member
    19
    Hi,
    My passenger side brake light stopped working on my S3 2002. I changed the bulb, but that did not solve the problem.
    Can someone offer any advice as to what might be causing this? is this a common issue?
    Thanks,
  2. Lemon S3
    Lemon S3 Alex
    1,390
    41
    I have the same problem, it's an intermittent fault, I'm guessing a bad connection somewhere.
  3. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,825
    107
    i had this on my 01 S3
    first i thought dodgy connection on the bulb... turned out to be the brake switch on the pedal,
    worth a look as they arent expensive
  4. Squirrelofdoom
    Squirrelofdoom Member
    673
    23
    yeah. If you can, scan it to see if a brake light switch fault comes up. Otherwise I would say just swap the brake light switch because it's so cheap. 5 minute job mate, really easy. Had to do mine recently because ALL of my brake lights stopped working (lol) :)
  5. Lemon S3
    Lemon S3 Alex
    1,390
    41
    Miss read your original post, glanced over 'brake'. Mine's the light rather than the brake light.
  6. richardshoes
    19
    Thanks for the comments. I'll report back when it's fixed. Cheers
  7. richardshoes
    19
    Replaced brake switch and this fixed the problem. Thanks
