Passenger front door not locking
choimaloy Oct 6, 2012
  1. choimaloy
    choimaloy Member
    111
    Hi guys I have problem with the front passenger door not locking,power to the door is there as the windows and mirrors and lighting all work but it just doesn't lock with the fob or by using the key in the drivers door I just don't understand it.also the mirror moves when operated but doesn't heat up like the driver one,could it be related.
  2. choimaloy
    choimaloy Member
    111
    Also forgot mention that all the other doors when locked and I open the passenger door the alarm goes off if that helps anyone.
  3. choimaloy
    choimaloy Member
    111
    Anyone have any ideas
  4. choimaloy
    choimaloy Member
    111
    Anyone else had this problem
  5. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    I would take a guess at this being an issue with the wiring loom from the door to the body.
  6. As above sounds like its a wiring fault, but could also be the mechanism, if theyre anything like the mk4 golfs they do fail,
  7. choimaloy
    choimaloy Member
    111
    I've had the harness out the car and checked it also I changed the locks while ago when the micro switch went it,the old lock I changed didn't lock either so it's got me beat as everything else works on the door.
  8. Silky
    Silky Member
    51
    I've got a similar problem (few threads below this).
    Can't open my n/s/r door from the outside, as it seems the electrics have failed. I can't open it from the inside either as the child lock is on
  9. Silky
    Silky Member
    51
    I'm going to take the doorcard off and see if I can see what is going on with it. Sounds electrical, same as yours. However maybe yours has just one wire broken
  10. Woorlord
    Woorlord shifting to Hyperspace... . VCDS Map User
    951
    my child lock is off - and my n/s/r has this problem occasionally. Checked the body-door wires and seem OK. VAG-COM does report single wire operation but no more details. Looked up the code in the workshop manual and advises: check wiring and check lock. Replace as necessary!!
    Have a salvaged lock to try - just need time to fit.
    Going to re-check wiring also again.
  11. hades-
    9,481
    646
    check drivers door wires from car to body
    its normaly that side that fails.
  12. choimaloy
    choimaloy Member
    111
    Well I tryed a different loom tonite and the problem still remains,so my thinking is the it has something to do with the window motor as everything plugs into that.
  13. choimaloy
    choimaloy Member
    111
    Anyone out there that can help?
  14. choimaloy
    choimaloy Member
    111
    Well today I finally got to the bottom of why my door wasn't looking,after changing the window motor and still no joy I turned my attention to the socket on the car body where the wiring harness plugs in to and there I found 2 pins that had snapped clean off.what I thought was going to need to buy a internal harness but then I had the idea of using some map pins and force each down each of the holes where the pins had snapped to make a connection and it works,every thing is working beautifully now full central locking.so if anyone is having this problem check the pins in the socket.
