passenger door problem
Adam-D Mar 14, 2008
  1. Adam-D
    Adam-D Member
    457
    when my passenger door is closed from the inside it never closes properly,
    if yo close it from the outside wheli keeping pressure on it, it does,
    but there has to be somthing wrong, any ides,? its really annoying and i cringe every time it has to be slammmed shut
  2. billybravo
    billybravo Active Member
    1,045
    sounds like its out of line the catch might need a little adjustment or the door has dropped but this can be ajusted at the hinge.
  3. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,776
    33
    Ditto what Craig has said. It's quite common for the doors to drop on these. Only takes one fatty pulling themselves out of their seat using the top of the door frame to misalign it!
    Check that the latch is on tight, use some thread lock on the bolts if it's not. You can also try lifting the door by just giving it a good heave to bring it closer to straight.
  4. Adam-D
    Adam-D Member
    457
    right ill have a look see if i can rectyfy the problem
  5. simonwjones
    simonwjones Member
    366
    I get this occasionally on my A6.
    Its the door lock asembly. I simply spray WD40 into it and problem goes away.
    Simon
  6. Jimbo.King
    Jimbo.King Active Member VCDS Map User
    269
    50
    My passanger door is suffering from "lack of use", due to this the door hinges have gone tight and so have the little rollers that keep it open in the 4 different stages, even with oil/wd40 it is still suffering but not as bad.
    When someone gets in and is not used to shutting the door it only closes on the first latch, this is down to tight hinges and people not wanting to slam the door.
    Open the passanger side door and feel if it is tight on the hinges compared to the drivers door.
    You could be suffering with the same.
