Passenger door fault
D4YEW May 30, 2014
  1. D4YEW
    D4YEW New Member
    14
    Hi I have a 2007 s3, I am currently having a intermittent fault with my passenger door, some times when I press the fob twice the passenger door will not unlock , I can carry on pressing and it still will not do anything , meaning I have to let my girlfriend in via the handle inside the car, next day it will work fine ? any ideas. Thanks in advance
  2. D4YEW
    D4YEW New Member
    14
    Any one ?
  3. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    Have you had it scanned for faults using VCDS? This is always the first port of call.
  4. LFCwilson
    LFCwilson New Member
    Hi. Old post sorry I know. I have this exact same problem with my 57 plate S3. did you manage to fix this in the end?
  5. leshkin
    leshkin Hold my beer... VCDS Map User Gold Supporter Team Sepang Audi S3
    2,602
    1,519
    A scan with VCDS will tell you if you have intermittent communication with any of the door control modules. 8P has a common problem with the door wiring harness getting pinched and wires broken inside the rubber door wiring boot. I had this on the front door, but the rear was the one that was affected due to them being daisy chained. Anyway, lots of info on this if you search.
    If wiring is not an issue, then its time to look at lock module itself.
  6. armstrong_21490
    armstrong_21490 Member
    87
    15
    I'm having the same problem with my passenger door but haven't got around to looking at it yet. This is what VCDS says
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
    Part No SW: 8P0 959 802 J HW: 8P0 959 802 J
    Component: Tuer-SG H03 0060
    Coding: 0004732
    Shop #: WSC 06314 000 00000
    VCID: 4382C60D02AB3339329-8016
    2 Faults Found:
    01553 - Motor for Central Locking; Passenger Door (V57); Lock
    012 - Electrical Fault in Circuit
    00929 - Locking Module for Central Locking; Front Passenger Side (F221)
    008 - Implausible Signal
    Is this likely to be the wiring or the locking module??
    Ross
  7. leshkin
    2,602
    1,519
    This might help (from http://wiki.ross-tech.com/wiki/index.php/00929)
    00929 - Locking Module for Central Locking; Front Passenger Side (F221): Implausible Signal
    Possible Symptoms
    • Door Locks not working properly
    Possible Causes
    • Wiring/Connectors from/to Locking Module for Central Locking; Front Passenger Side (F221) faulty
    • Voltage Supply for Locking Module for Central Locking; Front Passenger Side (F221) faulty
    • Door Lock Mechanics are stiff/partially seized
    • Locking Module for Central Locking; Front Passenger Side (F221) faulty
    Possible Solutions
    • Check Wiring/Connectors from/to Locking Module for Central Locking; Front Passenger Side (F221)
    • Check Voltage Supply for Locking Module for Central Locking; Front Passenger Side (F221)
    • Check Door Lock Mechanics/Operation
    • Check Locking Module for Central Locking; Front Passenger Side (F221)
    So going by that, I'd start by doing the cheap/free bits first like checking wiring to the module between the pillar and door, then if that brings no results check that the locking mechanism is properly lubricated, etc.
    Hopefuly, it's just a wiring break, which is a simple fix with a soldering iron or replacing the wiring harness for the door, chi will be around 100GBP.
  8. armstrong_21490
    87
    15
    Cheers bud forgot to look on the ross tech website to cross check the fault codes
    Ross
