Parts Required for Cam/Timing Belt Change - S3 2007
Boydie Jul 26, 2011
  1. Boydie
    Boydie Boycie VCDS Map User
    3,207
    314
    Lads
    Getting my belt done and sourcing my own parts.
    So I need:
    Water pump (£44 from ECP)
    Timing Belt (£35 from ECP)
    Coolant
    Tensioners Idlers and Dampners?? (£93 from ECP, £27 from buypartsby??)
    Is this correct? Anything else worth doing?
    This is the link to the over running alternator pulley from buypartsby. There are two stated for my car, which one?
    Belt Tensioner Pulley | Audi S3 2.0000 2007 | BuyPartsBy
    Andrew
  2. Boydie
    3,207
    314
    Anyone?
  3. mike foster
    3,967
    Talk to Dave at Stoke Audi
    For such an important element of the engine I suggest you go for OEM parts only and you should replace all parts 'in contact' with the belt.
    He will tell you what parts are required and give you a price which will include a discount for ASN members.
  4. RallyX
    RallyX Flat Out VCDS Map User
    143
    Does it really matter? they are the same part no.
  5. Boydie
    3,207
    314
    I live in Northern Ireland and have an account with TPS so will be using them more than likely for the belt kit.
