parts needed for cambelt and water pump ? help
S23 Feb 13, 2013
  1. S23
    S23 Member
    139
  2. glenandem
    glenandem Active Member
    786
    64
    hi mate,i recently did mine and not sure what engine you got but with my 1.9 tdi i replaced the thermostat if its not been done for a while as you got the coolant drained anyway,maybe aux belts if theyre tired maybe?
    i did a oil change while i was doing the cambelt change and had the covers off underneath and left it to drain for a bit so if you need a oil change why not do it?
    and finally dont forget antifreeze oh and have you got a timing pin kit,you can get them off ebay for a tenner to lock the pump and crank?
    cant think of anything else!
  3. S23
    S23 Member
    139
    thanks mate ok ill get a thermostat as well i has a mini service done a month ago so all levels are all toped up
    i think you get a pin with the kit as it states that its everything thats needed
    engine is a 1.8t quattro
