Part Number Needed Please...
S3MMA Aug 29, 2011
  1. S3MMA
    S3MMA Member
    235
    Does anyone know the part number for the side skirt clips on the s3? Mine has come loose at the very end...I am assuming this just clips back on?
  2. gary3306
    gary3306 Active Member VCDS Map User
    989
    41
    8L0 853 909, CLIP
    Hope that's what you're after
  3. vrbob
    vrbob Thats no Moon, Thats a space station!
    2,375
    171
    Sometimes the bit that the screws go into on the side skirt actually part company which means that the door blade comes away from the door. If you remove the door blade ( 4 screws on inside edge of the door and slide door blade to remove from lugs on door) you can glue the fixing strip using epoxy glue back into the door blade and then refit to the door which should now be nice and flush.
  4. S3MMA
    S3MMA Member
    235
    Tried glue its not stuck looks messy now
  5. vrbob
    2,375
    171
    worked ok for me but did use lots of glue to get the strip to stay in the door blade.
    Has the strip on the inside of the door blade come away at the end nearest the rear of the car?? as this seems to be most common guess it gets knocked more opening the door etc.
    Im not 100% sure but i thinki the strip that the screws hold into in my car was part of the door blade so if not fixable it would need a whole new one.
    Good luck on your fix
  6. Dan-Jnr
    Dan-Jnr Well-Known Member
    1,234
    386
    Mine has also done the same. I think a blob of glue and some tape to let it set should do the trick.
  7. gary3306
    989
    41
    Anyway, it was a pleasure, don't mention it :asskicking:
  8. dannyh
    dannyh Nogaro S3
    791
    12
    can you buy these and fit them to an A3????
  9. LukeTripod87
    LukeTripod87 Active Member
    373
    52
    ^^ You can indeed!
  10. dannyh
    dannyh Nogaro S3
    791
    12
    is it easy???
  11. S3MMA
    S3MMA Member
    235
    I have bought the clips from Audi 58p each
