Part 3 - Racelogic Traction Control
RichA3Turbo Nov 11, 2004
  1. RichA3Turbo
    5,089
    Well after buying the thing months ago, i finally got around to finish the installation and calibrating it.
    I had to buy some weatherproof plugs as the connectors are in a place thats likely to get damp when it rains (under the scuttle panel). I spent a couple of hours this evening fitting the new connectors (very intricate wiring!) and now its all complete and it WORKS! woohoo
    calibrated the wheel speeds at 100mph so they are accurate at speed and then found a wet road.
    Now, in 2n gear in the wet, youd get to about 3500rpm at W.O.T just when boost kicks in and the wheels would break traction and spin upto the redline with the car going somewhat sideways as a result...
    NOW, you get it on boost in the wet in 2nd gear, and its so discrete you hear it an dont feel it... It VERy quickly cuts the injectiors to each cylinder in order until traction is gained...Can now use full power in the wet without traction being a problem. VERY impressed with it!
    As for launch, well i need to sort that out. The wheel speeds are not being picked up until about 25mph, so this causes it to misfire at low speed regardless... What im doing as a stop gap is to set the minimum active speed to 30nph so it wont use it at low speed...Fine for the time being until i can sort it.
    Its going to be a winning combination when i fit the LSD... Traction will NOT be a problem... AT ALL! /ubbthreads/images/graemlins/grin.gif
  2. leespears1
    leespears1 Member
    261
    absolute monster!
  3. Rich, Rich, RIch. When will you ever stop!/ubbthreads/images/graemlins/crazy.gif
    /ubbthreads/images/graemlins/beerchug.gif
  4. RichA3Turbo
    5,089
    [ QUOTE ]
    [/ QUOTE ]
    i wont
  5. JamesA3
    JamesA3 Member
    238
    Sounds good mate, when you getting the LSD
  6. RichA3Turbo
    5,089
    [ QUOTE ]
    [/ QUOTE ]
    When i can afford it! /ubbthreads/images/graemlins/crazy.gif
  7. jimboA3
    jimboA3 Member
    336
    Awesome Rich - my mate with the 170bhp 106 rallye has this witing to fit. Cant wait to see how it works on the road ! /ubbthreads/images/graemlins/laugh.gif
  8. RichA3Turbo
    5,089
    its a real b*stard to fit! Not hard, just VERY awkward. Vehicle wiring diagrams are essential (Cheers HTC!) The setup is very complex and i feel its going to take me AGES to get perfect.
    Rich
  9. Khufu
    Khufu Well-Known Member
    5,704
    31
    Did the A3/S3 originally come with traction control (TCS) before changing to ESC? If so I take it that it wasnt any use compared to Racelogic.
  10. RichA3Turbo
    5,089
    Im not entirely sure... But i know that it would have been complete boll*x in comparison
    Rich
  11. cybrey
    cybrey Member
    331
    [ QUOTE ]
    [/ QUOTE ]
    Think the S3 did.. A3 didn't ..
  12. Ryanc
    Ryanc Active Member
    1,321
    thats the beauty of a s3,haldex controller -job done.
  13. HTC
    HTC Active Member
    3,428
    9
    Once the setup it correct it will definately be worth it!
