parrot volume to quite
andi m Oct 31, 2010
  1. andi m
    andi m New Member VCDS Map User
    12
    hi there, fitted a 3200 parrot into the bose equiped a3 via the mute and phone input pins, and the call volume is too quite, the volume on the parrot is on max and the car radio has no effect on this, is there a setting in the radio to adjust this,
    cheers andi
  2. s8craig
    1,746
    53
    Have you have used the line outputs from the parrot rather than the speaker level outs, I found these to be too quiet.
    Find the two pins on the 8 pin speaker mute kit connector that carries the speaker outputs and use these to drive the radio TEL+ TEL- inputs.
    Or if you have it the speaker wires.
