Parrot MK6100 only playing through front speakers
MikeSel^ Feb 21, 2010
  1. MikeSel^
    MikeSel^ Moderator Staff Member Moderator Team Navarra TFSI Owners Group Audi S3 quattro Manual
    1,138
    600
    Hello All
    I am running a Parrot MK6100 car kit in my 55 plate 8P A3 Sportback.
    I love the product, but currently it only plays through the dash mounted speakers. I am sure it's something to do with the wiring, but I am lost when it's not inside a PC!!
    The stereo simply says Concert on it, it's a CD player not tape. But I am not sure which generation it is.
    I would love to get the other speakers hooked up if possible.
    Any help would be appreciated.
    Mike
    *Prepared to be flamed for inability to find anything of relevance using search :sadlike:
  2. S3 TRS
    S3 TRS Active Member
    496
    226
    43
    i had my A4 done with a PARROT MKi9100 kit. i was told by the fitter (got it from carphone warehouse) that because the wires for the rear speakers ran from the Sub woofer in the boot, the speakers couldnt be connected to the parrot to have all the speakers used in the car.
    it probably can be done but not sure how.
    also, i have an ipod kit, so not too bothered if only my 2 front speakers are used for the telephone as im not playing music through it.
    i would take it down to an auto electrician and get him to see if it can be done.
    is it not playing through the front door speakers? or do you mean its just playing through the 2 speakers next to the air vents?
  3. MikeSel^
    1,138
    600
    Ok. That makes sense, I've never seen the sub in my boot but apparently I have one!
    I shall try and find a said professional.
    Thanks for the info!
    Mike
  4. MikeSel^
    1,138
    600
    Sorry missed the last questions.
    It's just the vent speakers I think.
    I was thinking of getting an iPod kit, I've got an iPhone 3G S. Just testing the water currently as there's so many to choose from.
  5. Cruiser89
    Cruiser89 Advanced In Car Tech Site Sponsor
    1,484
    222
    Parrot Kits only work through the front speakers.
    There is no way to do it or no need.
  6. MikeSel^
    1,138
    600
    Thanks. There is a need if you want to stream audio via Bluetooth.
    I guess the Denison is the best method.
  7. S3 TRS
    496
    226
    43
    in my a4 its on the back right behind a panel. not sure if its the same in the A3 though.
    good luck, hope you get something sorted. but bear in mind you might have to feed some cables from the sub to the radio to get it to work. and i meant the amp is in the boot, which the speakers connect to, not the sub.
  8. Xmay4444
    Xmay4444 On Point!!
    258
    Just had my Parrot MKi9200 fitted today and my rear speakers are working.
  9. AndyMac
    9,832
    46
    You need to use an adapter to feed the audio from the parrot into the CD input on the HU, then the HU will control the sound. Can't imagine how bad it must sound trying to play music from such a puny device directly to the speakers.
  10. Cruiser89
    1,484
    222
    Ahh ok i thought we were just talking about calls.
    If you are playing music it will.
    For calls there is no need!
