parrot kit. no rear sound
deano1978 Jul 9, 2013
  1. deano1978
    deano1978 different gear
    713
    80
    Anybody know how to get the rear speakers working with the parrot kit mki9100???
    Works fine up front. Just not coming out of the rear.
  2. hitman1978
    hitman1978 Member
    118
    When I got mine fitted I was told you need a special lead that plugs into the amp that costs about £80, I never bothered and just use the fronts
  3. subaru swift
    subaru swift Member
    154
    front speaker's for me too
  4. hades-
    9,480
    646
    as above onthe lead or a good sparkie to wire it
    but WHY ?
  5. deano1978
    713
    80
    Dont know what yours are like but mine runs (powered) on its own,works with radio off.
    So no tone controls or master volume.
    The main reason for this parrot is because it streams music via bluetooth. All works good except ive a seperate power amp and 10" sub thats not in use when streaming.
    Guess il have to go the wire connects route
  6. deano1978
    713
    80
    I found autoleads does them at £35 inc del...
    Sot-1002hb lead (sound on top lead)
    Well after hours of installing and loads of wires tucked behind a single din,
    I have my parrot and blutooth coming from all speakers incl sub.
    But i get a massive thump when switched on and off from the sub and some crackles from speakers.
    But sounds ok when up and running
    cant have it all!!!!!!
    Is this ground related. Also when no musics on and i rev i can hears the speakers reving too,slightly thou.
  7. stuhow3361
    stuhow3361 Member
    210
    14
    Had mine fitted by a specialist firm we clean for who also do the covert stuff for the local rozzers.All i had to buy was the lead to the amp which is vehicle specific and approx £35.The parrot still only works through the front speakers though but i think this is the norm.
