Parking System settings, Tyre Pressure Monitoring settings
AlexP Apr 14, 2010
  1. AlexP
    AlexP New Member
    Anyone know if you can enable parking system plus using VCDS, if you only have the standard parking system on a B8 A4? It only has the rear parking sensors but can the graphical interface be switched on via VAG.com or something?
    Also, is the same thing possible for the tire pressure monitoring? I heard it uses the existing ABS sensors to detect drop in tyre pressure?? Wondered if it can be enabled with a bit of VCDS magic?!
    Cheers,
    Alex.
  2. NHN
    29,398
    1,738
    TBH you need to check your wiring for tpms 1st as on the 8P that uses same system as in abs sensors, you have to stick a few wires in to make work along with a button, where as yours is all menu driven huh.
    Parking plus maybe possible, but you also need to check your sensor type fitted along with module version before enabling anything.
