parking sensors
bearder2006 Mar 12, 2012
  1. bearder2006
    bearder2006 Member
    205
    think one of my parking sensor have gone any idea of price or part number 2006 cab
  2. NHN
    29,593
    1,782
    Sensors run at about £70-80 mate, then need painting, assuming oem of course, have you got a long beep at rear when sticking in reverse?
  3. stocky#1
    stocky#1 Member
    70
    Can you increase the volume of the beeps when you have parking sensors already?
  4. NHN
    29,593
    1,782
    If oem then yes either via vcds or dis.
  5. stocky#1
    stocky#1 Member
    70
    Yes they should be OEM
    Any chance you could tell me what to change?
    Also don't forget about that AUX in you mentioned before. Cheers
  6. Rheady
    Rheady Member
    71
    Hello NHN mine beeps sometimes but works fine. What is the long beep. I thought it could be because the car was rolling forward slightly when I engaged reverse.
  7. NHN
    29,593
    1,782
    Its an error on the system which could be a sensor, the buzzer or the module at fault, needs a scan or measuring blocks checked to determine whats causing the beep.
  8. bearder2006
    bearder2006 Member
    205
    yes it has a long beep
  9. Playsatan
    Playsatan New Member
    24
    Had this on mine, long beep is just to let you know they're not working and not to rely on them.
    Unfortunately the guys at my local dealer did not know this and when I put it in for them to be replaced they promptly reversed my car into another one when moving it into the body shop. Even though that's the only thing it was booked in for.
  10. bearder2006
    bearder2006 Member
    205
    Ive tried put it in reverse with ignition on 3 are load ticking and one is very quiet , does this sound like one has gone ?
  11. NHN
    29,593
    1,782
    Could try swapping them round see if it changes on a different loom connection, but its probably a sensor at ault.
  12. bearder2006
    bearder2006 Member
    205
    any one know part number please
  13. NHN
    29,593
    1,782
    There are varied ones tbh, whats the diameter of yours ones?
  14. bearder2006
    bearder2006 Member
    205
    not shore
  15. Joe_Murphy21187
    Joe_Murphy21187 S-Tronic
    1,064
    71
    If you ring Audi and give them your VIN number they should be able to tell you the part number...
  16. Rheady
    Rheady Member
    71
    How do they fit into the bumper?
  17. NHN
    29,593
    1,782
    Bumpers come with brackets fitted.
  18. williams
    williams Member
    78
    i've got one of a s4 cab 2008 in met blue its got number 1 687 755 A if its any good to you
  19. NHN
    29,593
    1,782
    Thats not it.
