parking sensors ?
matt e Dec 30, 2010
  1. matt e
    matt e New Member
    Hello ,have recently brought a 2001 a3 1.8t and hadnt noticed untill the other day that it had factory fitted parking sensors i put the car into reverse and it gave me one long continuous beep before going off and now does this 75% of the time when engaging reverse does anyone have any ideas of either how to make them work properly or to turn them off alltogether
    thanks matt
  2. Carpy25
    Carpy25 Member
    279
    got the be fused , pulling the right fuse would shut them off as long as they are on a fuse of their own you would have no problems , are you syre their factory and not after market ?
    Rob
  3. NHN
    29,328
    1,708
    Its probably got a sensor fault as they usually do a very short beep to confirm working & a longer beep when there's a fault.
    Check the sensors are plugged in properly as this can happen, if they are then need to get it on vagcom to check ideally.
