Parking sensors retrofit
lionyo Feb 25, 2011
  1. lionyo
    lionyo Member
    145
    Hi,
    I have a donner car that I want to remove the parking sensors off and put them on to my car!
    How hard is it and what would it require doing/buying?
    Many thanks!
  2. Triple.O.G
    Triple.O.G Active Member
    1,113
    It's not a job I'd fancy taking on. Means drilling your bumper, might have to cut and splice all sorts of wires (I'm not sure if there's a connector) and again will need coding.
  3. benr
    benr Member
    819
    I have no idea but AFAIK there are markings on the inside of the bumper for drilling. But as TOG said wiring could be a mare.
    If I was going to retrofit id probably go for a universal kit as there's nothing special about OE parking sensors.
  4. hybenz
    hybenz New Member
    10
    Have you seen this note on retrofitting? There are other resources about it on car repair guides and I have read from it that fitting them is a really easy DIY job. Usually it takes an hour unless you need to take the bumper off.
