Parking Sensors Installation & questions
DaveA3-TDI Aug 23, 2010
  1. DaveA3-TDI
    DaveA3-TDI Member
    249
    I am thinking of buying some rear parking sensors from here: Home for my 2004 A3 but I have a few questions first if anyone can help me ?
    1) Is it easy to take the rear bumper off a 3 door and will the markings for parking sensors already be on the inside of the bumper ?
    2) These sensors wire into the reverse light wiring, will this cause any problems to the car's canbus system ?
    3) Has anyone used this company or their parking sensors before and can recommend them ?
    They seem quite a bargain for colour coded sensors, is it too good to be true ? Any help is greatly appreciated.
  2. sub39h
    sub39h Active Member
    2,502
    1. yes it's pretty easy to take off the rear bumper. if you do a google search someone's put a workshop manual of how to do it on here. if i get a chance i'll dig it out for you later. however, no there will be no marking points on the bumper as far as i'm aware. cars that were equipped with parking sensors from the factory have mounting points for the sensors already fitted, so if you wanna go down the factory fit route you'll have to get a bumper from a car which had sensors from the factory.
    2. i've read that a lot of ppl have wired into the reverse light with no issues. double check with NHN
    3. no idea about the company. sorry. the audi accessories kits can be had quite cheaply off ebay tho.
  3. DaveA3-TDI
    DaveA3-TDI Member
    249
    Thanks for the info, tried a quick google search but couldn't find that workshop manual. If you could dig it out that would be great :) Can I ask what the audi accessories kits are ?
  4. sub39h
    2,502
  5. DaveA3-TDI
    DaveA3-TDI Member
    249
    I see :) Are they the ones that I would need enabled with vagcom ?
  6. Brian566
    Brian566 Member
    70
    Here is the link to removing the Rear Bumper
    it in three parts boot trim and lights as all these have to be removed
    VW AUDI Forum - VWAF
    You should see four cross marks on the inside of the bumper were the Auidi ones fit
  7. emeraldA3guy
    emeraldA3guy Member
    131
    I have the audi kit I installed it and its not working for some reason.
    The kit keeps beeping even if there is nothing behind the car.
    I took the bumper off and at a certain distance from the car the system works. Anyone know what the problem might be?
  8. DaveA3-TDI
    DaveA3-TDI Member
    249
    Thanks for all your help :)
  9. jb0o
    jb0o North East Forum Moderator Regional Rep Site Sponsor VCDS Map User
    2,664
    118
    When you say "took the bumper off and at a certain distance", maybe the wires get pushed back and interfere with each other when the bumper is fitted?
    Take a look at the wires and whack on some insulation tape.
